RUTX50 vpn client only on LAN
Hi
Setup of an openVPN client on a RUTX50 is done and running (with NordVPN).
Now I’d like to have only the LAN port 1 reaching the Internet via the OpenVPN server effectively “adopting” the server’s Public IP address.
The WIFI LAN should should reach the Internet via the routers WAN Internet.
Any advice to configure?
Thank you for reaching out.
For this case, I have created a guide going through all the steps needed to configure your described VPN traffic split.
VPN traffic split guide updated.zip (371.2 KB)
Let us know if this guide helps
Arnoldas.
