I upgraded the firmware to stable vers 7.15.4. There is a new version of the internal modem: how is it possible to upgrade it from RMS ?
Unfortunately modem firmware can only be upgraded if you have the device locally, due to the complicated nature of the procedure.
Can you in the first instance advise what is the reason for needing a modem upgrade?
Arturas
There is an update on Rutx50 and I thought of doing it, to keep the equipment aligned
Setup a reverse VPN and do it over that, we do it that way
