Thanks for your reply. First our network operator uses 5G NSA so I have to choose 5G+4G but the option does not exists without also enabling 3G.
Here are the logs (FIY I got the same error by using a L2TP-4G only SIM who is working correctly on a RUT241) :
Fri Aug 9 04:11:17 2024 daemon.info mobifd: [gsm.modem0] Config reload initiated
Fri Aug 9 04:11:17 2024 daemon.info mobifd: [gsm.modem0] SIM is ready
Fri Aug 9 04:11:17 2024 daemon.notice netifd: mob1s1a1 (10728): Stopping network mob1s1a1
Fri Aug 9 04:11:17 2024 daemon.notice netifd: mob1s1a1 (10728): Command failed: Not found
Fri Aug 9 04:11:17 2024 daemon.notice netifd: mob1s1a1 (10728): Command failed: Permission denied
Fri Aug 9 04:11:17 2024 daemon.notice netifd: Interface ‘mob1s1a1’ is now down
Fri Aug 9 04:11:18 2024 daemon.info dnsmasq[2178]: read /etc/hosts - 12 names
Fri Aug 9 04:11:18 2024 daemon.info dnsmasq[2178]: read /tmp/hosts/dhcp.cfg01411c - 4 names
Fri Aug 9 04:11:18 2024 daemon.info dnsmasq-dhcp[2178]: read /etc/ethers - 0 addresses
Fri Aug 9 04:11:19 2024 kern.info Mobile data disconnected (internal modem)
Fri Aug 9 04:11:19 2024 daemon.info gsmd[2344]: Modem 2-1 [2c7c:0800]
URC Event: ESM reject cause => Insufficient resources
Fri Aug 9 04:11:19 2024 daemon.info mobifd: [gsm.modem0] Modem settings init completed
Fri Aug 9 04:11:19 2024 daemon.info mobifd: [gsm.modem0] Starting connection setup
Fri Aug 9 04:11:19 2024 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with “15s” of timeout
Fri Aug 9 04:11:23 2024 user.notice qmux: mob1s1a1 teardown successful
Fri Aug 9 04:11:24 2024 daemon.info mobifd: [gsm.modem0] Connected to operator “Orange Orange”
Fri Aug 9 04:11:24 2024 daemon.info mobifd: [gsm.modem0] -CFUN- Functionality: “Full”
Fri Aug 9 04:11:24 2024 daemon.info mobifd: [gsm.modem0] -COPS- Mode: “Auto”, operator: “Orange Orange”
Fri Aug 9 04:11:24 2024 daemon.info mobifd: [gsm.modem0] -CREG- Mode: “Enabled (with location information)”, status: “Registered, home”, LAC: “12295”, cell ID: “38953009”, technology: “UTRAN”
Fri Aug 9 04:11:24 2024 daemon.info mobifd: [gsm.modem0] -CGREG- Mode: “Enabled (with location information)”, status: “Registered, home”, LAC: “12295”, cell ID: “38953009”, technology: “UTRAN”
Fri Aug 9 04:11:24 2024 daemon.info mobifd: [gsm.modem0] -CEREG- Mode: “Enabled (with location information)”, status: “Not registered”, LAC: “”, cell ID: “”, technology: “Unknown”
Fri Aug 9 04:11:24 2024 daemon.info mobifd: [gsm.modem0] -C5GREG- Mode: “Enabled (with location information)”, status: “Not registered”, LAC: “”, cell ID: “”, technology: “Unknown”
Fri Aug 9 04:11:25 2024 daemon.err mobifd: [gsm.modem0] Failed to get IP address from PDP context “1”
Fri Aug 9 04:11:28 2024 daemon.err mobifd: [gsm.modem0] Failed to get IP address from PDP context “1”
Fri Aug 9 04:11:31 2024 daemon.err mobifd: [gsm.modem0] Failed to get IP address from PDP context “1”
Fri Aug 9 04:11:34 2024 daemon.err mobifd: [gsm.modem0] Failed to get IP address from PDP context “1”
Fri Aug 9 04:11:37 2024 daemon.err mobifd: [gsm.modem0] Failed to get IP address from PDP context “1”
Fri Aug 9 04:11:37 2024 daemon.info mobifd: [gsm.modem0] Modem is attached to PS
Fri Aug 9 04:11:37 2024 daemon.notice netifd: Interface ‘mob1s1a1’ is setting up now
Fri Aug 9 04:11:37 2024 daemon.notice netifd: mob1s1a1 (11170): wwan[11170] Using wwan usb device on bus 2-1
Fri Aug 9 04:11:37 2024 daemon.notice netifd: mob1s1a1 (11170): wwan[11170] Using proto:qmapv5 device:/dev/cdc-wdm0 iface:wwan0 desc:Quectel RG50X
Fri Aug 9 04:11:38 2024 daemon.notice netifd: mob1s1a1 (11170): Calculated qmimux ifname: qmimux0
Fri Aug 9 04:11:38 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 10000 --set-autoconnect disabled
Fri Aug 9 04:11:38 2024 daemon.notice netifd: mob1s1a1 (11170): Informing driver of raw-ip for wwan0 …
Fri Aug 9 04:11:38 2024 user.notice root: uqmi -d /dev/cdc-wdm0 --timeout 6000 --wda-set-data-format --qos-format 0 --link-layer-protocol raw-ip --endpoint-type hsusb --endpoint-iface-number 4 --ul-protocol qmapv5 --dl-protocol qmapv5 --ul-max-datagrams 11 --ul-datagram-max-size 8192 --dl-max-datagrams 62 --dl-datagram-max-size 31744 --dl-min-padding 0
Fri Aug 9 04:11:38 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-client-id wds,23 --release-client-id wds --modify-profile 3gpp,1 --profile-name 1 --roaming-disallowed-flag no
Fri Aug 9 04:11:39 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --get-client-id wds
Fri Aug 9 04:11:39 2024 daemon.notice netifd: mob1s1a1 (11170): 23
Fri Aug 9 04:11:39 2024 daemon.notice netifd: mob1s1a1 (11170): cid4: 23
Fri Aug 9 04:11:39 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --wds-bind-mux-data-port --mux-id 1 --ep-iface-number 4 --set-client-id wds,23
Fri Aug 9 04:11:39 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-ip-family ipv4 --set-client-id wds,23
Fri Aug 9 04:11:39 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-client-id wds,23 --start-network --profile 1 --ip-family ipv4
Fri Aug 9 04:11:43 2024 user.notice mobile.sh: QMI call error, reason type 3GPP: “Authentication failed” “Call failed”
Fri Aug 9 04:11:43 2024 daemon.notice netifd: mob1s1a1 (11170): pdh4: QMI call error, reason type 3GPP: “Authentication failed”
Fri Aug 9 04:11:43 2024 daemon.notice netifd: mob1s1a1 (11170): “Call failed”
Fri Aug 9 04:11:43 2024 daemon.notice netifd: mob1s1a1 (11170): Unable to connect IPv4
Fri Aug 9 04:11:43 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --get-client-id wds
Fri Aug 9 04:11:43 2024 daemon.notice netifd: mob1s1a1 (11170): 24
Fri Aug 9 04:11:43 2024 daemon.notice netifd: mob1s1a1 (11170): cid6: 24
Fri Aug 9 04:11:43 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --wds-bind-mux-data-port --mux-id 1 --ep-iface-number 4 --set-client-id wds,24
Fri Aug 9 04:11:43 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-ip-family ipv6 --set-client-id wds,24
Fri Aug 9 04:11:43 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-client-id wds,24 --start-network --ip-family ipv6 --profile 1
Fri Aug 9 04:11:46 2024 user.notice mobile.sh: QMI call error, reason type 3GPP: “Authentication failed” “Call failed”
Fri Aug 9 04:11:46 2024 daemon.notice netifd: mob1s1a1 (11170): pdh6: QMI call error, reason type 3GPP: “Authentication failed”
Fri Aug 9 04:11:46 2024 daemon.notice netifd: mob1s1a1 (11170): “Call failed”
Fri Aug 9 04:11:46 2024 daemon.notice netifd: mob1s1a1 (11170): Unable to connect IPv6
Fri Aug 9 04:11:46 2024 daemon.notice netifd: mob1s1a1 (11170): Releasing client-id 23 on /dev/cdc-wdm0
Fri Aug 9 04:11:47 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-client-id wds,23 --release-client-id wds
Fri Aug 9 04:11:47 2024 daemon.notice netifd: mob1s1a1 (11170): Releasing client-id 24 on /dev/cdc-wdm0
Fri Aug 9 04:11:47 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-client-id wds,24 --release-client-id wds
Fri Aug 9 04:11:47 2024 user.notice mobile.sh: QMI call error, reason type 3GPP: “Authentication failed” “Call failed”
Fri Aug 9 04:11:47 2024 user.notice mobile.sh: Device not responding, resetting mobile network
Fri Aug 9 04:12:00 2024 daemon.notice netifd: mob1s1a1 (11170): Failed to create IPV4V6 connection
Fri Aug 9 04:12:07 2024 daemon.info gsmd[2344]: Modem 2-1 [2c7c:0800]
Fri Aug 9 04:12:11 2024 daemon.notice netifd: mob1s1a1 (11549): Stopping network mob1s1a1
Fri Aug 9 04:12:11 2024 daemon.notice netifd: mob1s1a1 (11549): Command failed: Not found
Fri Aug 9 04:12:11 2024 daemon.notice netifd: mob1s1a1 (11549): Command failed: Permission denied
Fri Aug 9 04:12:11 2024 daemon.notice netifd: Interface ‘mob1s1a1’ is now down
Fri Aug 9 04:12:11 2024 daemon.notice netifd: Interface ‘mob1s1a1’ is setting up now
Fri Aug 9 04:12:11 2024 daemon.notice netifd: mob1s1a1 (11588): wwan[11588] Using wwan usb device on bus 2-1
Fri Aug 9 04:12:11 2024 daemon.notice netifd: mob1s1a1 (11588): wwan[11588] Using proto:qmapv5 device:/dev/cdc-wdm0 iface:wwan0 desc:Quectel RG50X
Fri Aug 9 04:12:12 2024 daemon.info dnsmasq[2178]: read /etc/hosts - 12 names
Fri Aug 9 04:12:12 2024 daemon.info dnsmasq[2178]: read /tmp/hosts/dhcp.cfg01411c - 4 names
Fri Aug 9 04:12:12 2024 daemon.info dnsmasq-dhcp[2178]: read /etc/ethers - 0 addresses
Fri Aug 9 04:12:17 2024 user.notice qmux: mob1s1a1 teardown successful
Fri Aug 9 04:12:17 2024 daemon.notice netifd: mob1s1a1 (11588): Calculated qmimux ifname: qmimux0
Fri Aug 9 04:12:17 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 10000 --set-autoconnect disabled
Fri Aug 9 04:12:18 2024 daemon.notice netifd: mob1s1a1 (11588): Informing driver of raw-ip for wwan0 …
Fri Aug 9 04:12:18 2024 user.notice root: uqmi -d /dev/cdc-wdm0 --timeout 6000 --wda-set-data-format --qos-format 0 --link-layer-protocol raw-ip --endpoint-type hsusb --endpoint-iface-number 4 --ul-protocol qmapv5 --dl-protocol qmapv5 --ul-max-datagrams 11 --ul-datagram-max-size 8192 --dl-max-datagrams 62 --dl-datagram-max-size 31744 --dl-min-padding 0
Fri Aug 9 04:12:18 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-client-id wds,23 --release-client-id wds --modify-profile 3gpp,1 --profile-name 1 --roaming-disallowed-flag no
Fri Aug 9 04:12:19 2024 daemon.info gsmd[2344]: Modem 2-1 [2c7c:0800]
Fri Aug 9 04:12:32 2024 daemon.info gsmd[2344]: Modem 2-1 [2c7c:0800]
Fri Aug 9 04:12:34 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --get-client-id wds
Fri Aug 9 04:12:34 2024 daemon.notice netifd: mob1s1a1 (11588): 23
Fri Aug 9 04:12:34 2024 daemon.notice netifd: mob1s1a1 (11588): cid4: 23
Fri Aug 9 04:12:34 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --wds-bind-mux-data-port --mux-id 1 --ep-iface-number 4 --set-client-id wds,23
Fri Aug 9 04:12:34 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-ip-family ipv4 --set-client-id wds,23
Fri Aug 9 04:12:34 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-client-id wds,23 --start-network --profile 1 --ip-family ipv4
Fri Aug 9 04:12:38 2024 user.notice mobile.sh: QMI call error, reason type 3GPP: “Authentication failed” “Call failed”
Fri Aug 9 04:12:38 2024 daemon.notice netifd: mob1s1a1 (11588): pdh4: QMI call error, reason type 3GPP: “Authentication failed”
Fri Aug 9 04:12:38 2024 daemon.notice netifd: mob1s1a1 (11588): “Call failed”
Fri Aug 9 04:12:38 2024 daemon.notice netifd: mob1s1a1 (11588): Unable to connect IPv4
Fri Aug 9 04:12:38 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --get-client-id wds
Fri Aug 9 04:12:38 2024 daemon.notice netifd: mob1s1a1 (11588): 24
Fri Aug 9 04:12:38 2024 daemon.notice netifd: mob1s1a1 (11588): cid6: 24
Fri Aug 9 04:12:38 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --wds-bind-mux-data-port --mux-id 1 --ep-iface-number 4 --set-client-id wds,24
Fri Aug 9 04:12:38 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-ip-family ipv6 --set-client-id wds,24
Fri Aug 9 04:12:38 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-client-id wds,24 --start-network --ip-family ipv6 --profile 1
Fri Aug 9 04:12:42 2024 user.notice mobile.sh: QMI call error, reason type 3GPP: “Authentication failed” “Call failed”
Fri Aug 9 04:12:42 2024 daemon.notice netifd: mob1s1a1 (11588): pdh6: QMI call error, reason type 3GPP: “Authentication failed”
Fri Aug 9 04:12:42 2024 daemon.notice netifd: mob1s1a1 (11588): “Call failed”
Fri Aug 9 04:12:42 2024 daemon.notice netifd: mob1s1a1 (11588): Unable to connect IPv6
Fri Aug 9 04:12:42 2024 daemon.notice netifd: mob1s1a1 (11588): Releasing client-id 23 on /dev/cdc-wdm0
Fri Aug 9 04:12:42 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-client-id wds,23 --release-client-id wds
Fri Aug 9 04:12:42 2024 daemon.notice netifd: mob1s1a1 (11588): Releasing client-id 24 on /dev/cdc-wdm0
Fri Aug 9 04:12:42 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-client-id wds,24 --release-client-id wds
Fri Aug 9 04:12:42 2024 user.notice mobile.sh: Device not responding, resetting mobile network
Fri Aug 9 04:12:56 2024 daemon.notice netifd: mob1s1a1 (11588): Failed to create IPV4V6 connection
Fri Aug 9 04:13:02 2024 daemon.info gsmd[2344]: Modem 2-1 [2c7c:0800]
Fri Aug 9 04:13:06 2024 daemon.notice netifd: mob1s1a1 (12439): Stopping network mob1s1a1
Fri Aug 9 04:13:06 2024 daemon.notice netifd: mob1s1a1 (12439): Command failed: Not found
Fri Aug 9 04:13:06 2024 daemon.notice netifd: mob1s1a1 (12439): Command failed: Permission denied
Fri Aug 9 04:13:06 2024 daemon.notice netifd: Interface ‘mob1s1a1’ is now down
Fri Aug 9 04:13:06 2024 daemon.notice netifd: Interface ‘mob1s1a1’ is setting up now
Fri Aug 9 04:13:06 2024 daemon.notice netifd: mob1s1a1 (12477): wwan[12477] Using wwan usb device on bus 2-1
Fri Aug 9 04:13:06 2024 daemon.notice netifd: mob1s1a1 (12477): wwan[12477] Using proto:qmapv5 device:/dev/cdc-wdm0 iface:wwan0 desc:Quectel RG50X
Fri Aug 9 04:13:07 2024 daemon.info dnsmasq[2178]: read /etc/hosts - 12 names
Fri Aug 9 04:13:07 2024 daemon.info dnsmasq[2178]: read /tmp/hosts/dhcp.cfg01411c - 4 names
Fri Aug 9 04:13:07 2024 daemon.info dnsmasq-dhcp[2178]: read /etc/ethers - 0 addresses
Fri Aug 9 04:13:12 2024 user.notice qmux: mob1s1a1 teardown successful
Fri Aug 9 04:13:13 2024 daemon.notice netifd: mob1s1a1 (12477): Calculated qmimux ifname: qmimux0
Fri Aug 9 04:13:13 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 10000 --set-autoconnect disabled
Fri Aug 9 04:13:13 2024 daemon.notice netifd: mob1s1a1 (12477): Informing driver of raw-ip for wwan0 …
Fri Aug 9 04:13:13 2024 user.notice root: uqmi -d /dev/cdc-wdm0 --timeout 6000 --wda-set-data-format --qos-format 0 --link-layer-protocol raw-ip --endpoint-type hsusb --endpoint-iface-number 4 --ul-protocol qmapv5 --dl-protocol qmapv5 --ul-max-datagrams 11 --ul-datagram-max-size 8192 --dl-max-datagrams 62 --dl-datagram-max-size 31744 --dl-min-padding 0
Fri Aug 9 04:13:13 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-client-id wds,23 --release-client-id wds --modify-profile 3gpp,1 --profile-name 1 --roaming-disallowed-flag no
Fri Aug 9 04:13:14 2024 daemon.info gsmd[2344]: Modem 2-1 [2c7c:0800]
Fri Aug 9 04:13:27 2024 daemon.info gsmd[2344]: Modem 2-1 [2c7c:0800]
Fri Aug 9 04:13:29 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --get-client-id wds
Fri Aug 9 04:13:29 2024 daemon.notice netifd: mob1s1a1 (12477): 23
Fri Aug 9 04:13:29 2024 daemon.notice netifd: mob1s1a1 (12477): cid4: 23
Fri Aug 9 04:13:29 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --wds-bind-mux-data-port --mux-id 1 --ep-iface-number 4 --set-client-id wds,23
Fri Aug 9 04:13:29 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-ip-family ipv4 --set-client-id wds,23
Fri Aug 9 04:13:29 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-client-id wds,23 --start-network --profile 1 --ip-family ipv4
