RUTX50 swap between 4G and Starlink
We have configured RUTX50 with Failover and 4G as primary. When the 4G signal is weak the Failover take action and connects WAN but after a short time it reconnects 4G and it goes like this forth and back until the 4G signal is very weak. Is it possible to configure this threshold? I tried change the Low signal reconnect but it did not have any effect.
Hi Confido_inst,
For now, Failover depends on ping functionality to check WAN connectivity. Weak signal threshold is only available through SIM switch. In your case, I would suggest to increase count of pings to avoid switching WAN sources when fluctuation is only experienced. More information about RUTX50 failover HERE.
Let me know if this helps.
