RUTX_R_00.07.06.5
RUTX50 Speedtest > During test, Download Not showing any values… no matter which server I select. Upload works as normal.
If I use Web based Speedtest all works fine.
We’re aware of this issue, and our team is actively working on resolving it. You can expect to see the fixes in upcoming firmware releases.
Marijus
I have the same issue, it takes for ever to do the test. I’m also experiencing slow website loading times and only thing that changed was firmware update.
It seems this not firmware dependant we can see this happens on all our devices with different firmware versions.
Could you confirm this?
Yes, this is present on multiple firmware versions. As I said before, this will be fixed in upcoming firmware versions.
Marijus
