RUTX50 SNMP signal values after 07.08 release
I have been monitoring mobile network signal levels via SNMP polling quite a long time.
I noticed that after some 07.08 major release, modem returns crazy low (-32768) numbers while doing scanning.
This messes up visualization. I haven’t seen this behavior before 07.08 version. Before that modem returned zero if it didn’t see any signal values.
For some reason, RUTX09 doesn’t do same even with newest software. I don’t have other models to test with.
@Teltonika networks, could you have a look at this?
This is how it should look normally:
Could you please confirm if this issue occurs with the 7.09 firmware version as well? You can download the firmware here RUTX50 Firmware Downloads - Teltonika Networks Wiki
Hi Marija,
Yes, it does it with latest 7.09 also.
Thank you for confirming that. I have informed our RnD team about this issue, and I will let you know as soon as I receive any feedback from them.
We will need a troubleshoot file from you to check for any potential issues. I have sent you a form to fill out. Once you complete it, I will contact you privately regarding this. For the ticket ID, please use “7712”. Thank you.
