Hi, I have an RUT X 50. I have added a SIM card to SIM slot 2, but , although it connects to the network, and shows data connection state as Connected, I cannot get any data. I have tried switching the SIM card to SIM 1, and all works fine, so the SIM card works correctly, with the correct APN settings. I have called the helpline and all settings were checked. This looks like a hardware issue.
Hi willdebeest787,
Thanks for getting in touch!
If the issue is software-related, performing a firmware reflash via the Bootloader Menu may resolve it.
You can find a detailed step-by-step guide on how to reflash firmware via the Bootloader menu here:
Firmware downloads are available at:
Just to confirm — could you also check whether the APN settings for SIM1 and SIM2 are identical?
If they are the same and the issue persists, it’s likely hardware-related rather than configuration-based.
If your device is still under warranty, I would suggest contacting your reseller or sales representative to arrange a repair or replacement.
Let me know if you need any additional assistance.
