RUTX50 RMS athentication code
Hi all, I need an authentication code for connecting the device RUTX50 to RMS but unfortunately such an authentication code is not be provided while adding the device to the RSM. I tried it sometimes.
Is there another way to get such an authentication code?
Thanks for your effort in advance.
Hi thermomanager,
In most cases, authentication code is not required for device to connect to RMS. But if you are required to input the code, it can be seen from the RMS itself while adding the device. Kindly refer to this link as guide.
Let me know if this helps.
yes, the auth-code is needed because otherwise the router will not connect to the RMS, but when adding the RUTX50 as a new device, no auth-code is issued by the RMS, as described under your posted support link.
We are now simply dispensing with the RMS in this project
Nevertheless, thank you for your reply.
