Rutx50, puck-5 and puck-2
Is this a good setup on my caravan?? I already have a puck-5 v2. And I think the poynting mimo 4x4 is to expensive. The Gemeni told my that is good setup if I Mount the antennas 50cm between them.
The setup you described could work well. However, we cannot guarantee the performance of a particular antenna configuration without testing it in the actual installation.
Performance can vary depending on several factors, including the caravan’s construction, antenna placement, cable lengths, the surrounding environment, and local mobile network conditions.
Since you already have the Puck-5 V2, we recommend testing the proposed setup and evaluating its real-world performance first. This will help you determine whether it meets your requirements before investing in a more expensive 4x4 MIMO antenna.
T.
