RUTX50 - Not working with EE SIM
Hello all,
I’m struggling to get an EE data only SIM to work in my RUTX50 router, I’ve switched from three (which was working fine) but when I insert the EE SIM, I get Not Registered for the operator state.
I’ve tried the SIM in a mobile device and it works fine, so I don’t believe it’s an issue with the SIM. I’ve tried all the possible combinations for the apn (auto, manual with everything as the apn) also tried factory resetting the router all to no avail.
If anyone has any suggestions, or if you need any more details, please let me know!
Thanks,
I may be behind the times but shouldn’t this be everywhere and not everything?
If you are using some authentication e.g. PAP, also try it with no authentication.
Use PDP Type = IPv4
