Hello
The last thing I did when I was in my off-grid summer house was to update my RUTX50. I wouldn’t have done that. After the update, I could no longer access my router via the webgui. Everything else seems to work but it refuses mine to connect to 192.168.10.10 which is my router.
Is everything done now so I have to reset it or can my settings be saved?
Can you check if the box is accessible at 192.168.1.1 which is its default address?
Maybe it somehow reverted to this address during/after the update?
As you mentioned that you cannot access the router’s WebUI, have you tried accessing it via SSH? You can connect to your router using SSH by following the instructions on CLI.
Let me know how it goes!
I’ll try there next time I’m there.
Please keep me updated on how it goes! Thank you.
SSH works fine on 192.168.10.10. But really don’t know what to do now
I managed to update my firmware but the result is the same no difference = no webgui
So if you have SSH access to 192.168.10.10 you can reset your RUTX50 to factory defaults:
Yes, device will need to be configured again, but at least it should be accessible again on its WebGUI on address 192.168.1.1
I that worth trying?
I did that and it worked fine.
Okay sweet ![]()
So you can go ahead and re-configure your box as needed (I assume put it back to 192.168.10.10 as before) and you should be fine.
Can you do that - test WebGUI access again - and give a final ‘thumbs up’?
