RUTX50 new modem firmware
I have just received the notification for modem upgrade. I’m a bit reluctant to upgrade via the interface so I would like to know what’s changing in the new RG501QEUAAR12A11M4G_04.200.04.200. Can’t find release notes anywhere (if on the Quectel side, they are well hidden).
Secondly, it is safe to upgrade via the interface ?
Thanks for supporting
Upgraded 30+ RUTX50’s through web interface already - not a single one failed.
Be brave and go for it.
People reporting much better speeds afterwards.
@TeWe …I’ve been brave and it worked, actually. Concerning speed, it looks the same or a bit improved but speed depends on so many factors that it is not even worth mentioning.
Good to hear mate :slight_smile:
Yes, try to find the best physical location for your box to maximize signal strength.
Positioning and antenna adjustment are essential.
Happy weekend!
Had no issues upgrading modem via the server/interface, have noted no issues since upgrade. Unit was showing FW & Modem upgrades but I always manually upgrade FW, upgraded 08.1 from download then Modem on line, all appears well.
Same here - no issues whatsoever.
And yes, always FW first and then modem - with a few minutes in between.
How long did that modem upgrade take for you?
I did the upgrade via modem_updater and it took 13 hours!
Everything works great :smiley:
Did it via Web GUI and it took around 5 mins I guess :slight_smile:
On 30+ RUTX50’s.
No issues at all.
However, in your case, Teltonika already said that this was definitely not normal…
RUTX50 internal modem firmware upgrade - #9 by tirkiz
Same for me
