I am experiencing a recurring connectivity issue with a Teltonika RUTX50.
Device Information
Device: RUTX50
Firmware: RUTX_R_00.07.23.6
Modem: RG501Q-EU
Network Operator: SMARTY (Three UK)
APN: three.co.uk
Connection Type: 5G (NSA), VoLTE
PDP Type: IPv4
WAN Mode: NAT
Issue Description
The router starts normally and internet access works correctly after boot.
However, after a few minutes, the internet connection drops for several seconds before automatically reconnecting. This behaviour repeats continuously throughout operation.
The outage is brief, but it is enough to interrupt active sessions, video calls, and other internet-dependent services.
Troubleshooting Already Performed
Tested multiple SIM cards
Tested in multiple geographic locations
Tested with an external outdoor antenna
Factory reset and reconfigured the router
Verified APN settings
Confirmed issue occurs regardless of location or SIM card
The behaviour remains identical across all tests.
Current Mobile Signal Information
Connected Band: LTE B28
Bandwidth: 10 MHz
Signal Quality: 26% (Fair)
RSSI: -71 dBm
RSRP: -103 dBm
RSRQ: -13 dB
SINR: 10 dB
Current Mobile Settings
VoLTE: Auto
Preferred Network Type: 5G/4G/3G Auto
5G Mode: Auto
Band Selection: Auto
Low Signal Reconnect: Disabled
Log Findings
From the Troubleshoot package, I can see entries similar to:
Network device 'qmimux0' link is down
Interface 'mob1s1a1' is now down
Mobile data disconnected (internal modem)
followed a few seconds later by:
Network device 'wwan0' link is up
Interface 'mob1s1a1' is now up
Mobile data connected
This suggests that the mobile interface itself is dropping and reconnecting.
Additional Information
I have already contacted Teltonika support by phone and was advised to post here for further investigation.
I am currently generating a fresh Troubleshoot package after a clean reboot and without making any configuration changes, so that the issue can be captured under normal operation. I can provide this package and any additional logs requested.
Has anyone experienced similar behaviour, or are there any known issues with firmware version RUTX_R_00.07.23.6 that could cause periodic mobile interface resets?
Thank you.
