Gruby
May 2, 2024, 8:06am
1
I use my router for business and video conferences. So the connection is critical.
I get recuringly “Mobile data disconnected (internal modem)”,
This makes the router pretty much useless and unreliable!!! In need urgently HELP! because I need to work in 11 days mobile without any other internet connection as via RUTX50.
Firmware: RUTX_R_00.07.06.10
Log snipped:
Thu May 2 09:59:47 2024 daemon.info dnsmasq[3985]: read /etc/hosts - 4 addresses
Thu May 2 09:59:47 2024 daemon.info dnsmasq[3985]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Thu May 2 09:59:47 2024 daemon.info dnsmasq-dhcp[3985]: read /etc/ethers - 0 addresses
Thu May 2 09:59:48 2024 kern.info Mobile data connected (internal modem)
Thu May 2 09:59:48 2024 kern.info Joined 5G-NSA network (internal modem)
Thu May 2 09:59:48 2024 kern.info Connected to F SFR operator (internal modem)
Thu May 2 09:59:50 2024 kern.warn kernel: [ 1661.819407] ath10k_ahb a000000.wifi: Invalid VHT mcs 15 peer stats
Thu May 2 10:00:18 2024 daemon.notice wpa_supplicant[2205]: CTRL_IFACE: Detach monitor that cannot receive messages: /var/run/iwinfo-wlan0-1-2276\x00
Thu May 2 10:01:20 2024 daemon.notice wpa_supplicant[2205]: CTRL_IFACE: Detach monitor that cannot receive messages: /var/run/iwinfo-wlan0-1-2276\x00
Thu May 2 10:02:21 2024 daemon.notice wpa_supplicant[2205]: CTRL_IFACE: Detach monitor that cannot receive messages: /var/run/iwinfo-wlan0-1-2276\x00
Thu May 2 10:03:23 2024 daemon.notice wpa_supplicant[2205]: CTRL_IFACE: Detach monitor that cannot receive messages: /var/run/iwinfo-wlan0-1-2276\x00
Thu May 2 10:03:24 2024 daemon.notice netifd: Vodafon_Flex (8106): Mobile connection lost!
Thu May 2 10:03:24 2024 daemon.notice netifd: Interface ‘Vodafon_Flex’ has lost the connection
Thu May 2 10:03:24 2024 daemon.notice netifd: Network device ‘wwan0’ link is down
Thu May 2 10:03:24 2024 daemon.notice netifd: Vodafon_Flex (10278): Stopping network Vodafon_Flex
Thu May 2 10:03:25 2024 daemon.notice netifd: Vodafon_Flex (10278): Stopping network on /dev/cdc-wdm0!
Thu May 2 10:03:25 2024 user.notice netifd: uqmi -s -d /dev/cdc-wdm0 -t 3000 --set-client-id wds,14 --stop-network 0xFFFFFFFF --autoconnect
Thu May 2 10:03:25 2024 daemon.notice netifd: Vodafon_Flex (10278): “No effect”
Thu May 2 10:03:25 2024 daemon.notice netifd: Vodafon_Flex (10278): Releasing client-id 14 on /dev/cdc-wdm0
Thu May 2 10:03:25 2024 user.notice netifd: uqmi -s -d /dev/cdc-wdm0 -t 3000 --set-client-id wds,14 --release-client-id wds
Thu May 2 10:03:25 2024 daemon.notice netifd: Vodafon_Flex (10278): Command failed: Not found
Thu May 2 10:03:25 2024 daemon.notice netifd: Network device ‘qmimux0’ link is down
Thu May 2 10:03:25 2024 daemon.notice netifd: Interface ‘Vodafon_Flex_4’ has link connectivity loss
Thu May 2 10:03:25 2024 daemon.notice netifd: Interface ‘Vodafon_Flex_4’ is disabled
Thu May 2 10:03:25 2024 daemon.notice netifd: Vodafon_Flex (10278): Command failed: Permission denied
Thu May 2 10:03:25 2024 daemon.notice netifd: Interface ‘Vodafon_Flex’ is now down
Thu May 2 10:03:25 2024 daemon.notice netifd: Interface ‘Vodafon_Flex’ is setting up now
Thu May 2 10:03:25 2024 daemon.warn dnsmasq[3985]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Thu May 2 10:03:25 2024 daemon.notice netifd: Vodafon_Flex_4 (8117): udhcpc: SIOCGIFINDEX: No such device
Thu May 2 10:03:25 2024 daemon.notice netifd: Vodafon_Flex_4 (8117): udhcpc: received SIGTERM
Thu May 2 10:03:25 2024 daemon.notice netifd: Vodafon_Flex_4 (8117): udhcpc: unicasting a release of 100.117.75.241 to 100.117.75.242
Thu May 2 10:03:25 2024 daemon.notice netifd: Vodafon_Flex_4 (8117): udhcpc: sending release
Thu May 2 10:03:25 2024 daemon.notice netifd: Vodafon_Flex_4 (8117): udhcpc: can’t bind to interface qmimux0: No such device
Thu May 2 10:03:25 2024 daemon.notice netifd: Vodafon_Flex_4 (8117): udhcpc: bindtodevice: No such device
Thu May 2 10:03:25 2024 daemon.notice netifd: Vodafon_Flex_4 (8117): udhcpc: entering released state
Thu May 2 10:03:25 2024 daemon.notice netifd: Vodafon_Flex_4 (8117): Command failed: Permission denied
Thu May 2 10:03:25 2024 daemon.notice netifd: Interface ‘Vodafon_Flex_4’ is now down
Thu May 2 10:03:25 2024 daemon.notice netifd: Vodafon_Flex (10488): wwan[10488] Using wwan usb device on bus 2-1
Thu May 2 10:03:26 2024 daemon.notice netifd: Vodafon_Flex (10488): wwan[10488] Using proto:qmapv5 device:/dev/cdc-wdm0 iface:wwan0 desc:Quectel RG50X
Thu May 2 10:03:26 2024 daemon.info dnsmasq[3985]: read /etc/hosts - 4 addresses
Thu May 2 10:03:26 2024 daemon.info dnsmasq[3985]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Thu May 2 10:03:26 2024 daemon.info dnsmasq-dhcp[3985]: read /etc/ethers - 0 addresses
Thu May 2 10:03:26 2024 kern.info Mobile data disconnected (internal modem)
Thu May 2 10:03:27 2024 daemon.notice netifd: Vodafon_Flex (10488): Quering active sim position
Thu May 2 10:03:27 2024 daemon.notice netifd: Vodafon_Flex (10488): Calculated qmimux ifname: qmimux0
Thu May 2 10:03:27 2024 user.notice root: uqmi -d /dev/cdc-wdm0 --timeout 6000 --wda-set-data-format --qos-format 0 --link-layer-protocol raw-ip --endpoint-type hsusb --endpoint-iface-number 4 --ul-protocol qmapv5 --dl-protocol qmapv5 --ul-max-datagrams 11 --ul-datagram-max-size 8192 --dl-max-datagrams 62 --dl-datagram-max-size 31744 --dl-min-padding 0
Gruby
May 14, 2024, 11:09am
2
Still same issue after update to RUTX_R_00.07.07.1
Based on the information provided, it seems there may be more than just a connectivity problem. Have you made any additional changes to your mobile WAN interface? Additionally, you should check if your APN settings are correct. It appears that an incorrect APN might be causing connectivity issues.
Gruby
May 14, 2024, 12:09pm
5
HI… not as I know. The APN is set to ‘airtelwap.es’ for the Vodafone Spain SIM and to ‘internet.telekom’ for the Telekom Germany SIM.
The Issue starts anytime with the ‘Mobile data disconnected (internal modem)’ Log entry.
Do you have failover set up? Also, consider adjusting the “Use gateway metric” setting for Vodafone to a higher value than Telekom_work.
Could you please take a screenshot of the Status → Network → Mobile page when a disconnection occurs?
Additionally, is the connection stable with another SIM card?
Thanks and kind regards,
Gruby
May 14, 2024, 2:58pm
7
Hi, thanks for your feedback
I have now considered the Vodafone metric and changed it to 5 where Telekom Work is still at 6.
Failover has been disabled for a while to avoid interfering with this issue.
The same happens with the Telekom SIM and another Vodafone_DE SIM.
It feels like the disconnections are a bit less since the update to 07.07.1, but still there.
I will upload a screenshot the next time it happens.
Gruby
May 14, 2024, 5:26pm
8
Here now the requested screenshot:
Gruby
May 14, 2024, 5:29pm
9
And yes… it happens as well at places with better figures and as well with 5G.
Gruby
May 14, 2024, 5:33pm
10
Tue May 14 17:52:52 2024 daemon.notice wpa_supplicant[1677]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue May 14 17:52:53 2024 daemon.notice wpa_supplicant[1677]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue May 14 17:52:54 2024 daemon.notice wpa_supplicant[1677]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue May 14 17:55:03 2024 daemon.err wifi_scanner: Failed to scan wireless network
Tue May 14 17:58:17 2024 daemon.notice wpa_supplicant[1677]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue May 14 17:58:18 2024 daemon.notice wpa_supplicant[1677]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue May 14 17:58:19 2024 daemon.notice wpa_supplicant[1677]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue May 14 18:00:29 2024 daemon.err wifi_scanner: Failed to scan wireless network
Tue May 14 18:03:43 2024 daemon.notice wpa_supplicant[1677]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue May 14 18:03:44 2024 daemon.notice wpa_supplicant[1677]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue May 14 18:03:45 2024 daemon.notice wpa_supplicant[1677]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue May 14 18:05:54 2024 daemon.err wifi_scanner: Failed to scan wireless network
Tue May 14 18:08:35 2024 daemon.err wifi_scanner: Failed to scan wireless network
Tue May 14 18:11:17 2024 daemon.err wifi_scanner: Failed to scan wireless network
Tue May 14 18:13:58 2024 daemon.err wifi_scanner: Failed to scan wireless network
Tue May 14 18:17:12 2024 daemon.notice wpa_supplicant[1677]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue May 14 18:17:13 2024 daemon.notice wpa_supplicant[1677]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue May 14 18:17:14 2024 daemon.notice wpa_supplicant[1677]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue May 14 18:19:24 2024 daemon.err wifi_scanner: Failed to scan wireless network
Tue May 14 18:19:44 2024 daemon.notice netifd: ifWan1_4 (25760): udhcpc: broadcasting renew
Tue May 14 18:22:38 2024 daemon.notice wpa_supplicant[1677]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue May 14 18:22:39 2024 daemon.notice wpa_supplicant[1677]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue May 14 18:22:40 2024 daemon.notice wpa_supplicant[1677]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue May 14 18:24:49 2024 daemon.err wifi_scanner: Failed to scan wireless network
Tue May 14 18:28:03 2024 daemon.notice wpa_supplicant[1677]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue May 14 18:28:04 2024 daemon.notice wpa_supplicant[1677]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue May 14 18:28:05 2024 daemon.notice wpa_supplicant[1677]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue May 14 18:30:15 2024 daemon.err wifi_scanner: Failed to scan wireless network
Tue May 14 18:32:56 2024 daemon.err wifi_scanner: Failed to scan wireless network
Tue May 14 18:36:10 2024 daemon.notice wpa_supplicant[1677]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue May 14 18:36:11 2024 daemon.notice wpa_supplicant[1677]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue May 14 18:36:12 2024 daemon.notice wpa_supplicant[1677]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue May 14 18:38:21 2024 daemon.err wifi_scanner: Failed to scan wireless network
Tue May 14 18:41:03 2024 daemon.err wifi_scanner: Failed to scan wireless network
Tue May 14 18:42:23 2024 daemon.info hostapd: wlan1: STA f2:25:a2:29:89:68 IEEE 802.11: authenticated
Tue May 14 18:42:23 2024 daemon.info hostapd: wlan1: STA f2:25:a2:29:89:68 IEEE 802.11: associated (aid 1)
Tue May 14 18:42:23 2024 daemon.notice hostapd: wlan1: AP-STA-CONNECTED f2:25:a2:29:89:68 auth_alg=open
Tue May 14 18:42:23 2024 kern.notice RUT_7EE3_2G: WiFi client connected: F2:25:A2:29:89:68
Tue May 14 18:42:23 2024 daemon.info hostapd: wlan1: STA f2:25:a2:29:89:68 RADIUS: starting accounting session CEA1A04059DF7782
Tue May 14 18:42:23 2024 daemon.info hostapd: wlan1: STA f2:25:a2:29:89:68 WPA: pairwise key handshake completed (RSN)
Tue May 14 18:42:23 2024 daemon.notice hostapd: wlan1: EAPOL-4WAY-HS-COMPLETED f2:25:a2:29:89:68
Tue May 14 18:42:23 2024 daemon.info dnsmasq-dhcp[3410]: DHCPREQUEST(br-lan) 192.168.1.145 f2:25:a2:29:89:68
Tue May 14 18:42:23 2024 daemon.info dnsmasq-dhcp[3410]: DHCPACK(br-lan) 192.168.1.145 f2:25:a2:29:89:68 S20-von-Marco
Tue May 14 18:43:28 2024 daemon.notice hostapd: wlan1: AP-STA-DISCONNECTED f2:25:a2:29:89:68
Tue May 14 18:43:28 2024 kern.notice RUT_7EE3_2G: WiFi client disconnected: F2:25:A2:29:89:68
Tue May 14 18:43:28 2024 daemon.info hostapd: wlan1: STA f2:25:a2:29:89:68 IEEE 802.11: disassociated
Tue May 14 18:43:29 2024 daemon.info hostapd: wlan1: STA f2:25:a2:29:89:68 IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Tue May 14 18:44:17 2024 daemon.notice wpa_supplicant[1677]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue May 14 18:44:18 2024 daemon.notice wpa_supplicant[1677]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue May 14 18:44:19 2024 daemon.notice wpa_supplicant[1677]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue May 14 18:46:28 2024 daemon.err wifi_scanner: Failed to scan wireless network
Tue May 14 18:49:43 2024 daemon.notice wpa_supplicant[1677]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue May 14 18:49:44 2024 daemon.notice wpa_supplicant[1677]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue May 14 18:49:45 2024 daemon.notice wpa_supplicant[1677]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue May 14 18:49:45 2024 daemon.notice netifd: ifWan1_4 (25760): udhcpc: broadcasting renew
Tue May 14 18:51:54 2024 daemon.err wifi_scanner: Failed to scan wireless network
Tue May 14 18:54:35 2024 daemon.err wifi_scanner: Failed to scan wireless network
Tue May 14 18:57:16 2024 daemon.err wifi_scanner: Failed to scan wireless network
Tue May 14 19:00:31 2024 daemon.notice wpa_supplicant[1677]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue May 14 19:00:32 2024 daemon.notice wpa_supplicant[1677]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue May 14 19:00:33 2024 daemon.notice wpa_supplicant[1677]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue May 14 19:00:38 2024 daemon.info hostapd: wlan1: STA 60:e3:2b:1b:27:f4 IEEE 802.11: authenticated
Tue May 14 19:00:38 2024 daemon.info hostapd: wlan1: STA 60:e3:2b:1b:27:f4 IEEE 802.11: associated (aid 1)
Tue May 14 19:00:38 2024 daemon.notice hostapd: wlan1: STA-OPMODE-SMPS-MODE-CHANGED 60:e3:2b:1b:27:f4 off
Tue May 14 19:00:38 2024 daemon.notice hostapd: wlan1: AP-STA-CONNECTED 60:e3:2b:1b:27:f4 auth_alg=open
Tue May 14 19:00:38 2024 kern.notice RUT_7EE3_2G: WiFi client connected: 60:E3:2B:1B:27:F4
Tue May 14 19:00:38 2024 daemon.info hostapd: wlan1: STA 60:e3:2b:1b:27:f4 RADIUS: starting accounting session 5072FB194587D96C
Tue May 14 19:00:38 2024 daemon.info hostapd: wlan1: STA 60:e3:2b:1b:27:f4 WPA: pairwise key handshake completed (RSN)
Tue May 14 19:00:38 2024 daemon.notice hostapd: wlan1: EAPOL-4WAY-HS-COMPLETED 60:e3:2b:1b:27:f4
Tue May 14 19:00:38 2024 daemon.info dnsmasq-dhcp[3410]: DHCPREQUEST(br-lan) 192.168.1.130 60:e3:2b:1b:27:f4
Tue May 14 19:00:38 2024 daemon.info dnsmasq-dhcp[3410]: DHCPACK(br-lan) 192.168.1.130 60:e3:2b:1b:27:f4 DESKTOP-OP8P0DI
Tue May 14 19:00:39 2024 daemon.notice hostapd: wlan1: STA-OPMODE-SMPS-MODE-CHANGED 60:e3:2b:1b:27:f4 dynamic
Tue May 14 19:00:41 2024 daemon.notice hostapd: wlan1: STA-OPMODE-SMPS-MODE-CHANGED 60:e3:2b:1b:27:f4 off
Tue May 14 19:02:09 2024 daemon.info hostapd: wlan1: STA b8:5f:98:78:28:b3 IEEE 802.11: authenticated
Tue May 14 19:02:09 2024 daemon.info hostapd: wlan1: STA b8:5f:98:78:28:b3 IEEE 802.11: associated (aid 2)
Tue May 14 19:02:09 2024 daemon.notice hostapd: wlan1: AP-STA-CONNECTED b8:5f:98:78:28:b3 auth_alg=open
Tue May 14 19:02:09 2024 kern.notice RUT_7EE3_2G: WiFi client connected: B8:5F:98:78:28:B3
Tue May 14 19:02:09 2024 daemon.info hostapd: wlan1: STA b8:5f:98:78:28:b3 RADIUS: starting accounting session A6CCE42C2BBBD63D
Tue May 14 19:02:09 2024 daemon.info hostapd: wlan1: STA b8:5f:98:78:28:b3 WPA: pairwise key handshake completed (RSN)
Tue May 14 19:02:09 2024 daemon.notice hostapd: wlan1: EAPOL-4WAY-HS-COMPLETED b8:5f:98:78:28:b3
Tue May 14 19:02:10 2024 daemon.info dnsmasq-dhcp[3410]: DHCPDISCOVER(br-lan) b8:5f:98:78:28:b3
Tue May 14 19:02:10 2024 daemon.info dnsmasq-dhcp[3410]: DHCPOFFER(br-lan) 192.168.1.168 b8:5f:98:78:28:b3
Tue May 14 19:02:10 2024 daemon.info dnsmasq-dhcp[3410]: DHCPREQUEST(br-lan) 192.168.1.168 b8:5f:98:78:28:b3
Tue May 14 19:02:10 2024 daemon.info dnsmasq-dhcp[3410]: DHCPACK(br-lan) 192.168.1.168 b8:5f:98:78:28:b3 amazon-9b57bdfc1
Tue May 14 19:02:42 2024 daemon.err wifi_scanner: Failed to scan wireless network
Tue May 14 19:02:58 2024 kern.warn kernel: [54138.788315] ath10k_ahb a800000.wifi: Invalid VHT mcs 15 peer stats
Tue May 14 19:03:21 2024 daemon.info hostapd: wlan1: STA f2:25:a2:29:89:68 IEEE 802.11: authenticated
Tue May 14 19:03:21 2024 daemon.info hostapd: wlan1: STA f2:25:a2:29:89:68 IEEE 802.11: associated (aid 3)
Tue May 14 19:03:21 2024 daemon.notice hostapd: wlan1: AP-STA-CONNECTED f2:25:a2:29:89:68 auth_alg=open
Tue May 14 19:03:21 2024 kern.notice RUT_7EE3_2G: WiFi client connected: F2:25:A2:29:89:68
Tue May 14 19:03:21 2024 daemon.info hostapd: wlan1: STA f2:25:a2:29:89:68 RADIUS: starting accounting session F6A1BD2731FF322F
Tue May 14 19:03:21 2024 daemon.info hostapd: wlan1: STA f2:25:a2:29:89:68 WPA: pairwise key handshake completed (RSN)
Tue May 14 19:03:21 2024 daemon.notice hostapd: wlan1: EAPOL-4WAY-HS-COMPLETED f2:25:a2:29:89:68
Tue May 14 19:03:21 2024 daemon.info dnsmasq-dhcp[3410]: DHCPREQUEST(br-lan) 192.168.1.145 f2:25:a2:29:89:68
Tue May 14 19:03:21 2024 daemon.info dnsmasq-dhcp[3410]: DHCPACK(br-lan) 192.168.1.145 f2:25:a2:29:89:68 S20-von-Marco
Tue May 14 19:04:46 2024 daemon.notice netifd: ifWan1_4 (25760): udhcpc: broadcasting renew
Tue May 14 19:05:23 2024 daemon.err wifi_scanner: Failed to scan wireless network
Tue May 14 19:08:05 2024 daemon.err wifi_scanner: Failed to scan wireless network
Tue May 14 19:10:30 2024 kern.warn kernel: [54591.393911] ath10k_ahb a800000.wifi: Invalid VHT mcs 15 peer stats
Tue May 14 19:10:46 2024 daemon.err wifi_scanner: Failed to scan wireless network
Tue May 14 19:12:17 2024 daemon.notice netifd: ifWan1_4 (25760): udhcpc: broadcasting renew
Tue May 14 19:12:21 2024 kern.warn kernel: [54701.779735] ath10k_ahb a800000.wifi: Invalid VHT mcs 15 peer stats
Tue May 14 19:13:27 2024 daemon.err wifi_scanner: Failed to scan wireless network
Tue May 14 19:16:02 2024 daemon.notice netifd: ifWan1_4 (25760): udhcpc: broadcasting renew
Tue May 14 19:16:09 2024 daemon.err wifi_scanner: Failed to scan wireless network
Tue May 14 19:17:55 2024 daemon.notice netifd: ifWan1_4 (25760): udhcpc: broadcasting renew
Tue May 14 19:18:00 2024 kern.warn kernel: [55040.518164] ath10k_ahb a800000.wifi: Invalid VHT mcs 15 peer stats
Tue May 14 19:18:23 2024 daemon.info hostapd: wlan1: STA 7a:83:87:4f:83:6d IEEE 802.11: authenticated
Tue May 14 19:18:23 2024 daemon.info hostapd: wlan1: STA 7a:83:87:4f:83:6d IEEE 802.11: associated (aid 4)
Tue May 14 19:18:23 2024 daemon.notice hostapd: wlan1: AP-STA-CONNECTED 7a:83:87:4f:83:6d auth_alg=open
Tue May 14 19:18:23 2024 kern.notice RUT_7EE3_2G: WiFi client connected: 7A:83:87:4F:83:6D
Tue May 14 19:18:23 2024 daemon.info hostapd: wlan1: STA 7a:83:87:4f:83:6d RADIUS: starting accounting session 6A6C5140ABDCC9E1
Tue May 14 19:18:23 2024 daemon.info hostapd: wlan1: STA 7a:83:87:4f:83:6d WPA: pairwise key handshake completed (RSN)
Tue May 14 19:18:23 2024 daemon.notice hostapd: wlan1: EAPOL-4WAY-HS-COMPLETED 7a:83:87:4f:83:6d
Tue May 14 19:18:24 2024 daemon.info dnsmasq-dhcp[3410]: DHCPREQUEST(br-lan) 192.168.1.209 7a:83:87:4f:83:6d
Tue May 14 19:18:24 2024 daemon.info dnsmasq-dhcp[3410]: DHCPACK(br-lan) 192.168.1.209 7a:83:87:4f:83:6d S23-von-Irina
Tue May 14 19:18:34 2024 kern.warn kernel: [55075.442412] ath10k_ahb a800000.wifi: Invalid VHT mcs 15 peer stats
Tue May 14 19:18:50 2024 daemon.err wifi_scanner: Failed to scan wireless network
Tue May 14 19:18:51 2024 daemon.notice netifd: ifWan1_4 (25760): udhcpc: broadcasting renew
Tue May 14 19:19:19 2024 daemon.notice netifd: ifWan1_4 (25760): udhcpc: broadcasting renew
Tue May 14 19:19:22 2024 daemon.notice netifd: ifWan1_4 (25760): udhcpc: broadcasting renew
Tue May 14 19:19:25 2024 daemon.notice netifd: ifWan1_4 (25760): udhcpc: broadcasting renew
Tue May 14 19:19:28 2024 daemon.notice netifd: ifWan1_4 (25760): udhcpc: broadcasting renew
Tue May 14 19:19:29 2024 kern.warn kernel: [55130.322840] ath10k_ahb a800000.wifi: Invalid VHT mcs 15 peer stats
Tue May 14 19:19:31 2024 daemon.notice netifd: ifWan1_4 (25760): udhcpc: lease lost, entering init state
Tue May 14 19:19:31 2024 daemon.notice netifd: Interface ‘ifWan1_4’ has lost the connection
Tue May 14 19:19:31 2024 daemon.warn dnsmasq[3410]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Tue May 14 19:19:31 2024 daemon.notice netifd: ifWan1_4 (25760): udhcpc: broadcasting discover
Tue May 14 19:19:32 2024 daemon.info dnsmasq[3410]: read /etc/hosts - 12 names
Tue May 14 19:19:32 2024 daemon.info dnsmasq[3410]: read /tmp/hosts/dhcp.cfg01411c - 4 names
Tue May 14 19:19:32 2024 daemon.info dnsmasq-dhcp[3410]: read /etc/ethers - 0 addresses
Tue May 14 19:19:32 2024 kern.info Mobile data disconnected (internal modem)
Tue May 14 19:19:34 2024 daemon.notice netifd: ifWan1_4 (25760): udhcpc: broadcasting discover
Tue May 14 19:20:02 2024 kern.notice IPv4 connectivity started to fail
Tue May 14 19:20:07 2024 kern.notice DNS resolution started to fail
Tue May 14 19:21:31 2024 daemon.err wifi_scanner: Failed to scan wireless network
Tue May 14 19:21:43 2024 daemon.err zerotier-one[4795]: sendto: Network unreachable
Tue May 14 19:24:46 2024 daemon.notice wpa_supplicant[1677]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue May 14 19:24:47 2024 daemon.notice wpa_supplicant[1677]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue May 14 19:24:48 2024 daemon.notice wpa_supplicant[1677]: wlan0-1: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Tue May 14 19:24:55 2024 kern.notice Password auth succeeded for admin on HTTP from 192.168.1.130
Tue May 14 19:24:55 2024 daemon.err uhttpd[2079]: vuci: accepted login for admin from 192.168.1.130
Tue May 14 19:25:44 2024 daemon.info mobifd: [gsm.modem0] Config reload initiated
Tue May 14 19:25:44 2024 daemon.info mobifd: [gsm.modem0] SIM is ready
Tue May 14 19:25:44 2024 daemon.notice netifd: ifWan1 (1818): Stopping network ifWan1
Tue May 14 19:25:44 2024 daemon.notice netifd: ifWan1 (1818): Stopping network on /dev/cdc-wdm0!
Tue May 14 19:25:44 2024 user.notice netifd: uqmi -s -d /dev/cdc-wdm0 -t 3000 --set-client-id wds,14 --stop-network 0xFFFFFFFF --autoconnect
Tue May 14 19:25:44 2024 daemon.notice netifd: ifWan1 (1818): Releasing client-id 14 on /dev/cdc-wdm0
Tue May 14 19:25:44 2024 user.notice netifd: uqmi -s -d /dev/cdc-wdm0 -t 3000 --set-client-id wds,14 --release-client-id wds
Tue May 14 19:25:44 2024 daemon.notice netifd: ifWan1 (1818): Command failed: Not found
Tue May 14 19:25:44 2024 daemon.notice netifd: Network device ‘qmimux0’ link is down
Tue May 14 19:25:44 2024 daemon.notice netifd: Interface ‘ifWan1_4’ has link connectivity loss
Tue May 14 19:25:44 2024 daemon.notice netifd: ifWan1_4 (25760): udhcpc: read error: Network is down, reopening socket
Tue May 14 19:25:45 2024 daemon.notice netifd: Interface ‘ifWan1_4’ is disabled
Tue May 14 19:25:45 2024 daemon.notice netifd: ifWan1 (1818): Command failed: Permission denied
Tue May 14 19:25:45 2024 daemon.notice netifd: Interface ‘ifWan1’ is now down
Tue May 14 19:25:45 2024 daemon.notice netifd: ifWan1_4 (25760): udhcpc: bind: No such device
Tue May 14 19:25:45 2024 daemon.notice netifd: Interface ‘ifWan1_4’ is now down
Tue May 14 19:25:45 2024 daemon.info dnsmasq[3410]: read /etc/hosts - 12 names
Tue May 14 19:25:45 2024 daemon.info dnsmasq[3410]: read /tmp/hosts/dhcp.cfg01411c - 4 names
Tue May 14 19:25:45 2024 daemon.info dnsmasq-dhcp[3410]: read /etc/ethers - 0 addresses
Tue May 14 19:25:45 2024 kern.info Mobile data disconnected (internal modem)
Tue May 14 19:25:46 2024 daemon.info mobifd: [gsm.modem0] Modem settings init completed
Tue May 14 19:25:46 2024 daemon.info mobifd: [gsm.modem0] Starting connection setup
Tue May 14 19:25:46 2024 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with “15s” of timeout
Tue May 14 19:25:46 2024 daemon.info mobifd: [gsm.modem0] Connected to operator “vodafone ES”
Tue May 14 19:25:46 2024 daemon.info mobifd: [gsm.modem0] -CFUN- Functionality: “Full”
Tue May 14 19:25:46 2024 daemon.info mobifd: [gsm.modem0] -COPS- Mode: “Auto”, operator: “vodafone ES”
Tue May 14 19:25:46 2024 daemon.info mobifd: [gsm.modem0] -CREG- Mode: “Enabled (with location information)”, status: “Registered, home”, LAC: “3347”, cell ID: “258810570”, technology: “E-UTRAN”
Tue May 14 19:25:46 2024 daemon.info mobifd: [gsm.modem0] -CGREG- Mode: “Enabled (with location information)”, status: “Not registered”, LAC: “”, cell ID: “”, technology: “Unknown”
Tue May 14 19:25:46 2024 daemon.info mobifd: [gsm.modem0] -CEREG- Mode: “Enabled (with location information)”, status: “Registered, home”, LAC: “”, cell ID: “258810570”, technology: “E-UTRAN”
Tue May 14 19:25:46 2024 daemon.info mobifd: [gsm.modem0] -C5GREG- Mode: “Enabled (with location information)”, status: “Not registered”, LAC: “”, cell ID: “”, technology: “Unknown”
Tue May 14 19:25:46 2024 daemon.err mobifd: [gsm.modem0] Failed to get IP address from PDP context “1”
Tue May 14 19:25:49 2024 daemon.err mobifd: [gsm.modem0] Failed to get IP address from PDP context “1”
Tue May 14 19:25:52 2024 daemon.err mobifd: [gsm.modem0] Failed to get IP address from PDP context “1”
Tue May 14 19:25:55 2024 daemon.err mobifd: [gsm.modem0] Failed to get IP address from PDP context “1”
Tue May 14 19:25:58 2024 daemon.err mobifd: [gsm.modem0] Failed to get IP address from PDP context “1”
Tue May 14 19:25:58 2024 daemon.info mobifd: [gsm.modem0] Modem is attached to PS
Tue May 14 19:25:58 2024 daemon.notice netifd: Interface ‘ifWan1’ is setting up now
Tue May 14 19:25:59 2024 daemon.notice netifd: ifWan1 (2708): wwan[2708] Using wwan usb device on bus 2-1
Tue May 14 19:25:59 2024 daemon.notice netifd: ifWan1 (2708): wwan[2708] Using proto:qmapv5 device:/dev/cdc-wdm0 iface:wwan0 desc:Quectel RG50X
Tue May 14 19:25:59 2024 daemon.notice netifd: ifWan1 (2708): Quering active sim position
Tue May 14 19:25:59 2024 daemon.notice netifd: ifWan1 (2708): Calculated qmimux ifname: qmimux0
Tue May 14 19:25:59 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 10000 --set-autoconnect disabled
Tue May 14 19:25:59 2024 daemon.notice netifd: ifWan1 (2708): Informing driver of raw-ip for wwan0 …
Tue May 14 19:25:59 2024 user.notice root: uqmi -d /dev/cdc-wdm0 --timeout 6000 --wda-set-data-format --qos-format 0 --link-layer-protocol raw-ip --endpoint-type hsusb --endpoint-iface-number 4 --ul-protocol qmapv5 --dl-protocol qmapv5 --ul-max-datagrams 11 --ul-datagram-max-size 8192 --dl-max-datagrams 62 --dl-datagram-max-size 31744 --dl-min-padding 0
Tue May 14 19:26:00 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-client-id wds,14 --release-client-id wds --modify-profile 3gpp,1 --profile-name 1 --roaming-disallowed-flag no
Tue May 14 19:26:00 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --get-client-id wds
Tue May 14 19:26:00 2024 daemon.notice netifd: ifWan1 (2708): 14
Tue May 14 19:26:00 2024 daemon.notice netifd: ifWan1 (2708): cid4: 14
Tue May 14 19:26:00 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --wds-bind-mux-data-port --mux-id 1 --ep-iface-number 4 --set-client-id wds,14
Tue May 14 19:26:00 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-ip-family ipv4 --set-client-id wds,14
Tue May 14 19:26:00 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-client-id wds,14 --start-network --profile 1 --ip-family ipv4
Tue May 14 19:26:01 2024 daemon.notice netifd: ifWan1 (2708): pdh4: 875564672
Tue May 14 19:26:01 2024 daemon.notice netifd: ifWan1 (2708): 875564672
Tue May 14 19:26:01 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --get-client-id wds
Tue May 14 19:26:01 2024 daemon.notice netifd: ifWan1 (2708): 15
Tue May 14 19:26:01 2024 daemon.notice netifd: ifWan1 (2708): cid6: 15
Tue May 14 19:26:01 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --wds-bind-mux-data-port --mux-id 1 --ep-iface-number 4 --set-client-id wds,15
Tue May 14 19:26:01 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-ip-family ipv6 --set-client-id wds,15
Tue May 14 19:26:01 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-client-id wds,15 --start-network --profile 1 --ip-family ipv6
Tue May 14 19:26:01 2024 user.notice mobile.sh: QMI call error, reason type INTERNAL: “PDN IPv6 call disallowed” “Call failed”
Tue May 14 19:26:01 2024 daemon.notice netifd: ifWan1 (2708): pdh6: QMI call error, reason type INTERNAL: “PDN IPv6 call disallowed”
Tue May 14 19:26:01 2024 daemon.notice netifd: ifWan1 (2708): “Call failed”
Tue May 14 19:26:01 2024 daemon.notice netifd: ifWan1 (2708): Unable to connect IPv6
Tue May 14 19:26:01 2024 daemon.notice netifd: ifWan1 (2708): Releasing client-id 15 on /dev/cdc-wdm0
Tue May 14 19:26:01 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-client-id wds,15 --release-client-id wds
Tue May 14 19:26:02 2024 daemon.notice netifd: ifWan1 (2708): Setting up qmimux0
Tue May 14 19:26:02 2024 daemon.notice netifd: ifWan1 (2708): Setting dynamic MTU: 1500 on qmimux0
Tue May 14 19:26:02 2024 daemon.notice netifd: Interface ‘ifWan1’ is now up
Tue May 14 19:26:02 2024 daemon.notice netifd: Network device ‘wwan0’ link is up
Tue May 14 19:26:02 2024 daemon.notice netifd: ifWan1 (2708): Setting up qmimux0 V4 DCHP
Tue May 14 19:26:02 2024 daemon.notice netifd: Interface ‘ifWan1_4’ is enabled
Tue May 14 19:26:02 2024 daemon.notice netifd: Network device ‘qmimux0’ link is up
Tue May 14 19:26:02 2024 daemon.notice netifd: Interface ‘ifWan1_4’ has link connectivity
Tue May 14 19:26:02 2024 daemon.notice netifd: Interface ‘ifWan1_4’ is setting up now
Tue May 14 19:26:02 2024 daemon.notice netifd: ifWan1_4 (3127): udhcpc: started, v1.34.1
Tue May 14 19:26:02 2024 daemon.notice netifd: ifWan1_4 (3127): udhcpc: broadcasting discover
Tue May 14 19:26:02 2024 daemon.notice netifd: ifWan1_4 (3127): udhcpc: broadcasting select for 10.209.111.164, server 10.209.111.165
Tue May 14 19:26:02 2024 user.notice firewall: Reloading firewall due to ifup of ifWan1 (wwan0)
Tue May 14 19:26:02 2024 daemon.notice netifd: ifWan1_4 (3127): udhcpc: lease of 10.209.111.164 obtained from 10.209.111.165, lease time 7200
Tue May 14 19:26:02 2024 daemon.notice netifd: Interface ‘ifWan1_4’ is now up
Tue May 14 19:26:02 2024 daemon.info mobifd: Auto APN is disabled for ‘ifWan1’. Skipping Ping To DNS functionality
Tue May 14 19:26:02 2024 daemon.info dnsmasq[3410]: reading /tmp/resolv.conf.d/resolv.conf.auto
Tue May 14 19:26:02 2024 daemon.info dnsmasq[3410]: using nameserver 212.166.148.65#53
Tue May 14 19:26:02 2024 daemon.info dnsmasq[3410]: using nameserver 212.166.167.69#53
Tue May 14 19:26:02 2024 daemon.info dnsmasq[3410]: using only locally-known addresses for test
Tue May 14 19:26:02 2024 daemon.info dnsmasq[3410]: using only locally-known addresses for onion
Tue May 14 19:26:02 2024 daemon.info dnsmasq[3410]: using only locally-known addresses for localhost
Tue May 14 19:26:02 2024 daemon.info dnsmasq[3410]: using only locally-known addresses for invalid
Tue May 14 19:26:02 2024 daemon.info dnsmasq[3410]: using only locally-known addresses for bind
Tue May 14 19:26:02 2024 daemon.info dnsmasq[3410]: using only locally-known addresses for lan
Tue May 14 19:26:02 2024 daemon.info mobifd: Connection setup completed for ‘ifWan1’
Tue May 14 19:26:02 2024 daemon.info mobifd: Connection setup completed for modem: ‘gsm.modem0’
Tue May 14 19:26:04 2024 daemon.info dnsmasq[3410]: read /etc/hosts - 12 names
Tue May 14 19:26:04 2024 daemon.info dnsmasq[3410]: read /tmp/hosts/dhcp.cfg01411c - 4 names
Tue May 14 19:26:04 2024 daemon.info dnsmasq-dhcp[3410]: read /etc/ethers - 0 addresses
Tue May 14 19:26:05 2024 user.notice firewall: Reloading firewall due to ifup of ifWan1_4 (qmimux0)
Tue May 14 19:26:06 2024 daemon.err dnsmasq[3410]: failed to send packet: Operation not permitted
Tue May 14 19:26:08 2024 daemon.info dnsmasq[3410]: read /etc/hosts - 12 names
Tue May 14 19:26:08 2024 daemon.info dnsmasq[3410]: read /tmp/hosts/dhcp.cfg01411c - 4 names
Tue May 14 19:26:08 2024 daemon.info dnsmasq-dhcp[3410]: read /etc/ethers - 0 addresses
Tue May 14 19:26:08 2024 kern.info Mobile data connected (internal modem)
Tue May 14 19:26:08 2024 kern.info Joined LTE network (internal modem)
Tue May 14 19:26:08 2024 kern.info Connected to vodafone ES operator (internal modem)
After analyzing these logs, I would advise you to check if you are using the correct APN for your mobile provider’s data communication. Additionally, please go to Network → WAN and click “Edit” next to your mobile interface. In the new pop-up window, set PDP Type to “IPv4” since your device attempted unsuccessfully IPv6 communication.
