I’m experiencing lower-than-expected internet speeds with my RUTX50 router. Despite the device’s advertised capability of “up to” 3 Gbps, I am only able to achieve 300 Mbps download and 150 Mbps upload speeds. Here are the steps I’ve already taken to troubleshoot and optimize performance:
- Updated to the latest firmware (version 07.06.3).
- Conducted speed tests at various times to discount network congestion.
- Implemented a TTL increment in the firewall settings.
- Enabled software offloading.
- Enabled both software and hardware offloading.
- Attempted to blacklist individual and multiple bands.
- Switched to a different cellular tower to test for location-based issues.
- Tried a different network operator using a friend’s SIM card to rule out carrier-specific limitations.
- Connected directly via ethernet to rule out WiFi problems.
- Tried different antenna orientations. Having each antenna separated at least 45 degrees from the others seemed to produce the strongest signal.
Despite these efforts, I haven’t been able to surpass the aforementioned speeds. I’m reaching out for any advice, tips, or settings adjustments that might help me achieve better performance with my RUTX50. Any insights or recommendations would be greatly appreciated.
Thank you in advance for your assistance.
