RUTX50 Looses GPS signal and require reboot
Hi
My RUTX50 has worked fine from start with GPS but with the latest two firmware updates it has began to loose GPS signal after a week or two even if the unit is stationary.
Only way to restore it is a reboot of the unit.
Disconnecting and reconnecting of the GPS module does not work either.
Anyone else have this problem?
hey , when i faced the same issue i just restarted the gps service and was fine after that,
login to SSH as root and try /etc/init.d/gpsd restart
Yes, it also works to restart the service by SSH instead of a reboot.
However, after a week or so it will fail again, requiring another reboot (or by restart the GPS service by SSH).
The GPS service is not stable over time anymore…
