Hello and thanks for getting back so rapidly Rashid!
Role of the unifi is router my wifi including 2 switches and wlc for 2 AP:s. Its handling DHCP for my local network devices.
I meant DHCP is handled by my unifi router for internal devices on 192.168.0
As soon as the issue is replicated i will post logs here.
Her is the network config:
BusyBox v1.34.1 (2024-01-02 08:00:03 UTC) built-in shell (ash)
____ _ ___ ____
| _ \ _ | | / _ / |
| |) | | | | | | | _ \
| _ <| || | || || |) |
|| _\,|_|__/|____/
Teltonika RUTX series 2024
Device: RUTX50
Kernel: 5.10.199
Firmware: RUTX_R_00.07.06.1
Build: 0f141b8753
Build date: 2024-01-02 09:57:45
root@RUTX50:~#
root@RUTX50:~#
root@RUTX50:~#
root@RUTX50:~#
root@RUTX50:~#
root@RUTX50:~#
root@RUTX50:~#
root@RUTX50:~# cat /etc/config/network
config interface ‘loopback’
option device ‘lo’
option proto ‘static’
option ipaddr ‘127.0.0.1’
option netmask ‘255.0.0.0’
option _area_type ‘lan’
option area_type ‘lan’
config globals ‘globals’
option ula_prefix ‘fd3a:83a4:f458::/48’
config port ‘_lan1’
option enabled ‘1’
option autoneg ‘on’
option role ‘lan’
option port_num ‘1’
config port ‘_lan2’
option enabled ‘1’
option autoneg ‘on’
option role ‘lan’
option port_num ‘2’
config port ‘_lan3’
option enabled ‘1’
option autoneg ‘on’
option role ‘lan’
option port_num ‘3’
config port ‘_lan4’
option enabled ‘1’
option autoneg ‘on’
option role ‘lan’
option port_num ‘4’
config port ‘_wan5’
option enabled ‘1’
option autoneg ‘on’
option role ‘wan’
option port_num ‘5’
option ifname ‘eth1’
config device ‘br_lan’
option name ‘br-lan’
option type ‘bridge’
list ports ‘eth0’
config interface ‘lan’
option device ‘br-lan’
option ipaddr ‘192.168.1.1’
option netmask ‘255.255.255.0’
option ip6assign ‘60’
config interface ‘wan’
option device ‘eth1’
option proto ‘dhcp’
option metric ‘1’
option _area_type ‘wan’
option area_type ‘wan’
config interface ‘wan6’
option proto ‘dhcpv6’
option metric ‘2’
config switch
option name ‘switch0’
option reset ‘1’
option enable_vlan ‘1’
config switch_vlan
option device ‘switch0’
option vlan ‘1’
option vid ‘1’
option ports ‘1 2 3 4 0’
config switch_vlan
option vlan ‘2’
option vid ‘2’
option ports ‘5 0’
config interface ‘mob1s1a1’
option proto ‘wwan’
option modem ‘2-1’
option metric ‘3’
option sim ‘1’
option dhcpv6 ‘0’
option pdptype ‘ip’
option method ‘nat’
option pdp ‘1’
option pref_apn ‘434’
option auto_apn ‘0’
option apn ‘services.telenor.se’
option auth ‘pap’
config interface ‘mob1s2a1’
option proto ‘wwan’
option modem ‘2-1’
option metric ‘4’
option sim ‘2’
option dhcpv6 ‘0’
option pdptype ‘ip’
option method ‘nat’
option auth ‘none’
option auto_apn ‘1’
root@RUTX50:~#
