Hi, i have a RUTX50 connected to internet via 4G and latest firmware RUTX_R_00.07.06.5, and latest modem firmware
Now to my problem: once every 24 hours the unit hangs and gets unresponsive, i loose internet connection and i cant access it through the web interface so i have to unplug the power and plug it in again and then it works normally again, its very intermittent when this happens
it also happened with previous firmware and started for about three weeks ago and before that it worked very well
Im using it as a home router to one main computer and the rest is connected via wifi
Thank you in advance!
I think this is the 3 blinking led problem where the RUTX50 freezes in this mode. It’s an old problem and lots have written and discussed about it but it is NOT resolved.
