RUTX50 "Internal modem is unreachable"
I have an issue with RUTX50 – error “Internal modem is unreachable”.
I briefly checked the forum and similar threads already exist with no clear solution.
I am attaching the diagnostics mentioned in older threads:
Teltonika RUTX series 2025
Device: RUTX50
Kernel: 5.10.234
Firmware: RUTX_R_00.07.14
Build: 26ed73328ac
Build date: 2025-04-18 11:26:58
root@RUTX50:~# lsusb
Bus 003 Device 001: ID 1d6b:0002
Bus 001 Device 001: ID 1d6b:0002
Bus 004 Device 001: ID 1d6b:0003
Bus 002 Device 001: ID 1d6b:0003
root@RUTX50:~#
Matej
Based on the output of the lsusb command you provided, unfortunately, the modem is not recoverable.
The only solution in this case is to contact your reseller regarding the RMA process, if the device is still under warranty.
