LOFA
December 2, 2024, 3:01pm
1
RUT with firmware RUTX_R_00.07.11.1
I configured the router using the wiki guide How to set up a guest WiFi network.
internet browsing ok, DHCP ok but from the guest wifi I reach the lan devices, how can the guest wifi be isolated from the lan?
Best regards
Mike
December 2, 2024, 5:04pm
2
Double check your Inter-Zone forwarding settings
LOFA
December 2, 2024, 5:30pm
3
thank you for your replay.
I checked interzone, I’m posting the screenshots for your verify:
and Traffic-rules
Mike
December 2, 2024, 7:24pm
4
You interzone forwarding doesn’t look like the example, best you look again and if this is different, then you probably need to re-check everything.
https://wiki.teltonika-networks.com/view/How_to_set_up_a_guest_WiFi_network
LOFA
December 3, 2024, 11:20am
5
Thanks.
It works now.
I had a mistake in interzone forwarding.
Thank you a lot.
system
Closed
December 5, 2024, 11:20pm
6
