This question has been handled before, but things have changed in the RUTX50 firmware and it seems to been have made easier, but I can’t get it to work anyway… I Hope someone can help with some guidance.
I have:
- GPS signal with external antenna in the RUTX50
- MQTT broker enabled in the RUTX50 with default settings & anonumus access
- Modbus TCP server enabled on the RUTX50 with default settings
- Modbus TCP client enabled on the RUTX50 with default settings, collecting Register number 144, 146, 180 & 184 OK.
- MQTT Modbus Gateway enabled on the RUTX50 connecting to host 127.0.0.1 on port 1883 & request/response topics “gpsrequest” & “gpsresponse”.
- An external IP-device connected on the RUTX50 LAN containing a MQTT client. It’s connected OK to the RUTX50 MQTT Broker.
When setting up a MQTT subscription on the external IP-device I can’t get any data. Not sure what subscription filter and topic prefix to use to collect the GPS-data from the RUTX50.
