RUTx50 fw 7.11.3 Ipsec - CLI commands & "IPSec Failed to load Data"
Hi
I have a rutx50 that i am configuring a IPSec vpn on. Usually on previous models you can get the status/restart etc of ipsec from the cli.
When i use the command ipsec status (also tried ipsecstatus) i get command not found. Has this changed in the new firmwares?
ALso when configuring the tunnel via the webui i have been seeing “IPSec Failed to load Data” as a pop up message
Can any one assist or explain.
aaron
Hi…
Can you try…
root@device:/etc# ipsec statusall
Status of IKE charon daemon (strongSwan 5.9.6, Linux 5.15.149, mips):
uptime: 29 minutes, since May 28 10:49:50 2024
Hi
Managed to get the tunnel running in the end but still can’t get the status etc from cli.
See attached screenshot this is what I get when logged in as root on cli
Try:
  • swanctl -l
Starting from 7.11 firmware:
thank you that has worked. I did not see this in the release notes and not much mention of it on the wiki as far as i can see.
thank you
Hello @aaron451,
Could you please confirm if your issue has been resolved, or do you still need assistance with it?
This topic was automatically closed after 94 days. New replies are no longer allowed.
