How do I set up routing behind the ue with the framed routing function? I have the router in NAT Mode and enabled framed routing but when I try to ping another network client, my IP gets masked as the router IP. I tried to disable masquerading in the firewall zones but then I am not able to ping another client.
If you navigate to Network → WAN in the WebUI and click the Edit button next to the mobile interface, you will find the option to enable Framed Routing in the Advanced Settings.
thanks for your reply! Yeah I already enabled this option but when I try to ping another network client from behind the router, my IP Adress still gets masked as router IP.
