RUTX50 Fails to send SMS
Hi evryone,
I have the same problem with an TRB245.
In the WebUI even after a delete command, the SIM storage remained stuck at 9/10
root@TRB245:~# gsmctl -A 'AT+CPMS="SM","SM","SM"'
+CPMS: 9,10,9,10,9,10
root@TRB245:~# gsmctl -A 'AT+CMGF=1'
OK
root@TRB245:~# gsmctl -A 'AT+CMGD=1,4'
OK
root@TRB245:~# gsmctl -A 'AT+CPMS?'
+CPMS: "SM",9,10,"SM",9,10,"SM",9,10
root@TRB245:~# gsmctl -A 'AT+CPMS="ME","ME","ME"'
+CPMS: 0,255,0,255,0,255
root@TRB245:~# gsmctl -A 'AT+CGSMS=2'
OK
root@TRB245:~# gsmctl -S -s "+49151*** Test"
SMS sent: 1
@marius-machts Thanks. Tried, but without success, although a different error:
root@RUTX50:~# gsmctl -A 'AT+CPMS="SM","SM","SM"'
+CPMS: 7,30,7,30,7,30
root@RUTX50:~# gsmctl -A 'AT+CMGF=1'
OK
root@RUTX50:~# gsmctl -A 'AT+CMGD=1,4'
OK
root@RUTX50:~# gsmctl -A 'AT+CPMS?'
+CPMS: "SM",0,30,"SM",0,30,"SM",0,30
root@RUTX50:~# gsmctl -A 'AT+CPMS="ME","ME","ME"'
+CPMS: 0,127,0,127,0,127
root@RUTX50:~# gsmctl -A 'AT+CGSMS=2'
OK
root@RUTX50:~# gsmctl -S -s "PHONENUMBER Test"
[gsmctl_send_sms:22] error: ERROR: Request timed out
After resetting connection, the Failed to parse response returns:
[gsmctl_send_sms:22] error: ERROR: Failed to parse response
@Vilius any news on the error?
Tiago Malheiro
Thank you for the detailed information provided.
From the behavior described, the router is able to receive SMS messages successfully, while sending SMS fails both from the WebUI and CLI with the following error:
Since the same router can send SMS successfully when using a SIM card from another operator, this indicates that the router hardware and modem are functioning correctly. The issue is therefore likely related to operator-specific behavior or the response returned by the modem when attempting to send an SMS.
To investigate this further, we kindly ask you to provide the following additional information.
  1. Please execute the following command via SSH and provide the full output:
gsmctl -A 'AT+CMGS="+<phone_number>"'
  1. Network registration status: please run the following commands and share their outputs:
gsmctl -A 'AT+COPS?'
gsmctl -A 'AT+CREG?'
gsmctl -A 'AT+CGREG?'
  1. SIM card details: please confirm with your operator whether the SIM card supports outgoing SMS from data devices (routers/modems) . Some IoT or data-only SIM profiles allow receiving SMS but restrict sending.
I look forward to your reply.
Dear Villius,
Thanks for the support.
root@RUTX50:~# gsmctl -A 'AT+CMGS="+351<number>"'
+CMS ERROR: 304
root@RUTX50:~# gsmctl -A 'AT+CMGS="<number>"'
+CMS ERROR: 304
root@RUTX50:~# gsmctl -A 'AT+COPS?'
+COPS: 0,2,"26806",13
root@RUTX50:~# gsmctl -A 'AT+CREG?'
+CREG: 2,1,"BEBE","004AD1F",13
root@RUTX50:~# gsmctl -A 'AT+CGREG?'
+CGREG: 2,0
  1. Regarding the SIM card SMS support, the operator claims that there is no blocking. Furthermore, I can send SMS using the same SIM cards from a Quectel RM520N-GL modem.
Tiago Malheiro
For troubleshooting purposes, we will require more sensitive information from your end, such as the troubleshoot file, which may contain passwords, public IP addresses, serial numbers, and such. To avoid leaking this information, we have sent you a form to fill out, which you will receive in your e-mail inbox that you have registered your account with in the forums. In the Ticket ID field of the form, please enter the ID of this thread, which is 18515.
Hi Villius,
I have just submitted the form.
Tiago Malheiro
Hi Villius,
Any news on this?
Best,
Tiago
