RUTX50: Disable "Help us improve our products and services"
After upgrading my RUTX09 to a RUTX50 I encountered a prominent banner asking me to enable data analytics. Upon closing it it reappears after a new login.
Is there a workaround till the problem is fixed?
Patrick
To fix the popup message, go to System and then Setup Wizard. Select General, enable “Data analytics” setting, save them, and refresh the page. After that, disable same settings and save again. This should remove the permanent popup message.
Looks good so far. Thank you.
I’m glad it worked. If you encounter any other issues, please feel free to reach out again.
