Hi folks,
I’ve read a couple of threads and topics on this but did not find a solution that could remediate the error on my mobile connection on the RUTX50. In case I missed something please accept my apologies.
So I got this new RUTX50 device and put in a German O2 SIM card in Slot 1 and got a data connection for about - a couple of minutes - maybe an hour - I can’t tell.
After a couple of hours I came back and the mobile connection says " DATA CONNECTION Disconnected" . I tried to restart the modem, restarted the router, placed the device at a “better” location for improved signal strength - no luck.
I do run on FW Version RUTX_R_00.07.06.3.
What do I miss?
Any help is appreciated.
Thanks in advance for your assistance.
Alex
Following is the Troubleshoot => System-log:
{"Index":14,"MTU":1500,"Name":"br-lan","HardwareAddr":"IJcnG3nI","Flags":51,"AltAddrs":null,"Desc":""},"erspan0":{"Index":8,"MTU":1450,"Name":"erspan0","HardwareAddr":null,"Flags":18,"AltAddrs":null,"Desc":""},"eth0":{"Index":2,"MTU":1500,"Name":"eth0","HardwareAddr":"IJcnG3nI","Flags":51,"AltAddrs":null,"Desc":""},"eth1":{"Index":3,"MTU":1500,"Name":"eth1","HardwareAddr":"IJcnG3nJ","Flags":
Mon Jan 29 17:57:03 2024 daemon.err tailscaled[5319]: 2024/01/29 17:57:03 LinkChange: major, rebinding. New state: interfaces.State{defaultRoute=eth1 ifs={br-lan:[192.168.140.1/24 fd48:91a3:f935::1/60 llu6] eth1:[192.168.99.210/24 llu6] tailscale0:[100.108.33.8/32 fd7a:115c:a1e0::72ac:2108/128 llu6]} v4=true v6=true}
Mon Jan 29 17:57:03 2024 daemon.err tailscaled[5319]: 2024/01/29 17:57:03 dns: Set: {DefaultResolvers:[192.168.99.128] Routes:{tail373d4.ts.net.:[] ts.net.:[199.247.155.53 2620:111:8007::53]}+65arpa SearchDomains:[tail373d4.ts.net.] Hosts:5}
Mon Jan 29 17:57:03 2024 daemon.err tailscaled[5319]: 2024/01/29 17:57:03 dns: Resolvercfg: {Routes:{.:[192.168.99.128] ts.net.:[199.247.155.53 2620:111:8007::53]} Hosts:5 LocalDomains:[tail373d4.ts.net.]+65arpa}
Mon Jan 29 17:57:03 2024 daemon.err tailscaled[5319]: 2024/01/29 17:57:03 dns: OScfg: {Nameservers:[100.100.100.100] SearchDomains:[tail373d4.ts.net.] }
Mon Jan 29 17:57:03 2024 user.notice netifd: uqmi -s -d /dev/cdc-wdm0 -t 3000 --set-client-id wds,14 --release-client-id wds
Mon Jan 29 17:57:03 2024 daemon.err tailscaled[5319]: 2024/01/29 17:57:03 wgengine: set DNS config again after major link change
Mon Jan 29 17:57:03 2024 daemon.err tailscaled[5319]: 2024/01/29 17:57:03 Rebind; defIf="eth1", ips=[192.168.99.210/24 fe80::2297:27ff:fe1b:79c9/64]
Mon Jan 29 17:57:03 2024 daemon.err tailscaled[5319]: 2024/01/29 17:57:03 magicsock: 1 active derp conns: derp-4=cr1h44m0s,wr457ms
Mon Jan 29 17:57:03 2024 daemon.err tailscaled[5319]: 2024/01/29 17:57:03 post-rebind ping of DERP region 4 okay
Mon Jan 29 17:57:03 2024 user.info mwan3track[3204]: Detect ifdown event on interface mob1s1a1 ()
Mon Jan 29 17:57:03 2024 user.notice mwan3track[3204]: Interface mob1s1a1 () is offline
Mon Jan 29 17:57:03 2024 daemon.notice netifd: mob1s1a1 (10333): Command failed: Not found
Mon Jan 29 17:57:03 2024 daemon.notice netifd: mob1s1a1 (10333): Command failed: Permission denied
Mon Jan 29 17:57:03 2024 daemon.notice netifd: Interface 'mob1s1a1' is now down
Mon Jan 29 17:57:03 2024 daemon.err tailscaled[5319]: 2024/01/29 17:57:03 monitor: RTM_DELROUTE: src=, dst=fe80::/64, gw=, outif=320, table=254
Mon Jan 29 17:57:03 2024 daemon.err tailscaled[5319]: 2024/01/29 17:57:03 monitor: RTM_DELROUTE: src=, dst=fe80::/128, gw=, outif=320, table=255
Mon Jan 29 17:57:03 2024 daemon.err tailscaled[5319]: 2024/01/29 17:57:03 monitor: RTM_DELROUTE: src=, dst=fe80::b4a9:20ff:fe8b:5967/128, gw=, outif=320, table=255
Mon Jan 29 17:57:03 2024 daemon.err tailscaled[5319]: 2024/01/29 17:57:03 monitor: RTM_DELROUTE: src=, dst=ff00::/8, gw=, outif=320, table=255
Mon Jan 29 17:57:03 2024 daemon.err tailscaled[5319]: 2024/01/29 17:57:03 [RATELIMIT] format("monitor: %s: src=%v, dst=%v, gw=%v, outif=%v, table=%v")
Mon Jan 29 17:57:03 2024 daemon.err tailscaled[5319]: 2024/01/29 17:57:03 monitor: [unexpected] network state changed, but stringification didn't: interfaces.State{defaultRoute=eth1 ifs={br-lan:[192.168.140.1/24 fd48:91a3:f935::1/60 llu6] eth1:[192.168.99.210/24 llu6] tailscale0:[100.108.33.8/32 fd7a:115c:a1e0::72ac:2108/128 llu6]} v4=true v6=true}
Mon Jan 29 17:57:03 2024 daemon.err tailscaled[5319]: 2024/01/29 17:57:03 monitor: [unexpected] old: {"InterfaceIPs":{"br-lan":["192.168.140.1/24","fd48:91a3:f935::1/60","fe80::2297:27ff:fe1b:79c8/64"],"erspan0":null,"eth0":null,"eth1":["192.168.99.210/24","fe80::2297:27ff:fe1b:79c9/64"],"gre0":null,"gretap0":null,"ip6gre0":null,"ip6tnl0":null,"lo":["127.0.0.1/8","::1/128"],"miireg":null,"sit0":null,"tailscale0":["100.108.33.8/32","fd7a:115c:a1e0::72ac:2108/128","fe80::b6ee:3bac:3f7c:3e1a/64"],"wlan0":["fe80::2297:27ff:fe1b:79ca/64"],"wlan1":["fe80::2297:27ff:fe1b:79cb/64"],"wwan0":["fe80::b4a9:20ff:fe8b:5967/64"]},"Interface":{"br-lan":{"Index":14,"MTU":1500,"Name":"br-lan","HardwareAddr":"IJcnG3nI","Flags":51,"AltAddrs":null,"Desc":""},"erspan0":{"Index":8,"MTU":1450,"Name":"erspan0","HardwareAddr":null,"Flags":18,"AltAddrs":null,"Desc":""},"eth0":{"Index":2,"MTU":1500,"Name":"eth0","HardwareAddr":"IJcnG3nI","Flags":51,"AltAddrs":null,"Desc":""},"eth1":{"Index":3,"MTU":1500,"Name":"eth1","HardwareAddr":"IJcnG3nJ","Flags":
Mon Jan 29 17:57:03 2024 daemon.err tailscaled[5319]: 2024/01/29 17:57:03 monitor: [unexpected] new: {"InterfaceIPs":{"br-lan":["192.168.140.1/24","fd48:91a3:f935::1/60","fe80::2297:27ff:fe1b:79c8/64"],"erspan0":null,"eth0":null,"eth1":["192.168.99.210/24","fe80::2297:27ff:fe1b:79c9/64"],"gre0":null,"gretap0":null,"ip6gre0":null,"ip6tnl0":null,"lo":["127.0.0.1/8","::1/128"],"miireg":null,"sit0":null,"tailscale0":["100.108.33.8/32","fd7a:115c:a1e0::72ac:2108/128","fe80::b6ee:3bac:3f7c:3e1a/64"],"wlan0":["fe80::2297:27ff:fe1b:79ca/64"],"wlan1":["fe80::2297:27ff:fe1b:79cb/64"],"wwan0":null},"Interface":{"br-lan":{"Index":14,"MTU":1500,"Name":"br-lan","HardwareAddr":"IJcnG3nI","Flags":51,"AltAddrs":null,"Desc":""},"erspan0":{"Index":8,"MTU":1450,"Name":"erspan0","HardwareAddr":null,"Flags":18,"AltAddrs":null,"Desc":""},"eth0":{"Index":2,"MTU":1500,"Name":"eth0","HardwareAddr":"IJcnG3nI","Flags":51,"AltAddrs":null,"Desc":""},"eth1":{"Index":3,"MTU":1500,"Name":"eth1","HardwareAddr":"IJcnG3nJ","Flags":51,"AltAddrs":null,"Desc":""
Mon Jan 29 17:57:03 2024 daemon.err tailscaled[5319]: 2024/01/29 17:57:03 magicsock: 1 active derp conns: derp-4=cr1h44m0s,wr753ms
Mon Jan 29 17:57:04 2024 user.notice mwan3-hotplug[10490]: Execute disconnected event on interface mob1s1a1 (unknown)
Mon Jan 29 17:57:04 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:05 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:06 2024 daemon.info dnsmasq[24761]: read /etc/hosts - 4 addresses
Mon Jan 29 17:57:06 2024 daemon.info dnsmasq[24761]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Mon Jan 29 17:57:06 2024 daemon.info dnsmasq-dhcp[24761]: read /etc/ethers - 0 addresses
Mon Jan 29 17:57:06 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:06 2024 kern.info Mobile data disconnected (internal modem)
Mon Jan 29 17:57:06 2024 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with "3600s" of timeout
Mon Jan 29 17:57:06 2024 daemon.info mobifd: [gsm.modem0] Connected to operator "o2 - de+"
Mon Jan 29 17:57:06 2024 daemon.info mobifd: [gsm.modem0] -CFUN- Functionality: "Full"
Mon Jan 29 17:57:06 2024 daemon.info mobifd: [gsm.modem0] -COPS- Mode: "Auto", operator: "o2 - de+"
Mon Jan 29 17:57:06 2024 daemon.info mobifd: [gsm.modem0] -CREG- Mode: "Enabled (with location information)", status: "Registered, home", LAC: "51525", cell ID: "26517290", technology: "E-UTRAN-NR"
Mon Jan 29 17:57:06 2024 daemon.info mobifd: [gsm.modem0] -CGREG- Mode: "Enabled (with location information)", status: "Not registered", LAC: "", cell ID: "", technology: "Unknown"
Mon Jan 29 17:57:06 2024 daemon.info mobifd: [gsm.modem0] -CEREG- Mode: "Enabled (with location information)", status: "Registered, home", LAC: "51525", cell ID: "26517290", technology: "E-UTRAN-NR"
Mon Jan 29 17:57:06 2024 daemon.info mobifd: [gsm.modem0] -C5GREG- Mode: "Enabled (with location information)", status: "Not registered", LAC: "", cell ID: "", technology: "Unknown"
Mon Jan 29 17:57:07 2024 daemon.info mobifd: [gsm.modem0] IP address on PDP context "1": "10.113.115.85"
Mon Jan 29 17:57:07 2024 daemon.info dnsmasq[24761]: read /etc/hosts - 4 addresses
Mon Jan 29 17:57:07 2024 daemon.info dnsmasq[24761]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Mon Jan 29 17:57:07 2024 daemon.info dnsmasq-dhcp[24761]: read /etc/ethers - 0 addresses
Mon Jan 29 17:57:07 2024 daemon.notice netifd: Interface 'mob1s1a1' is setting up now
Mon Jan 29 17:57:07 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:07 2024 daemon.notice netifd: mob1s1a1 (11256): wwan[11256] Using wwan usb device on bus 2-1
Mon Jan 29 17:57:07 2024 daemon.notice netifd: mob1s1a1 (11256): wwan[11256] Using proto:qmapv5 device:/dev/cdc-wdm0 iface:wwan0 desc:Quectel RG50X
Mon Jan 29 17:57:08 2024 daemon.notice netifd: mob1s1a1 (11256): Quering active sim position
Mon Jan 29 17:57:08 2024 daemon.notice netifd: mob1s1a1 (11256): Calculated qmimux ifname: qmimux0
Mon Jan 29 17:57:08 2024 user.notice root: uqmi -d /dev/cdc-wdm0 --timeout 6000 --wda-set-data-format --qos-format 0 --link-layer-protocol raw-ip --endpoint-type hsusb --endpoint-iface-number 4 --ul-protocol qmapv5 --dl-protocol qmapv5 --ul-max-datagrams 11 --ul-datagram-max-size 8192 --dl-max-datagrams 62 --dl-datagram-max-size 31744 --dl-min-padding 0
Mon Jan 29 17:57:08 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:08 2024 daemon.notice netifd: mob1s1a1 (11256): Starting network mob1s1a1 using APN: internet
Mon Jan 29 17:57:08 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-client-id wds,14 --release-client-id wds --modify-profile --profile-identifier 3gpp,1 --profile-name profile1 --roaming-disallowed-flag no --auth-type none --apn internet --pdp-type ip
Mon Jan 29 17:57:09 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --get-client-id wds
Mon Jan 29 17:57:09 2024 daemon.notice netifd: mob1s1a1 (11256): 14
Mon Jan 29 17:57:09 2024 daemon.notice netifd: mob1s1a1 (11256): cid4: 14
Mon Jan 29 17:57:09 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --wds-bind-mux-data-port --mux-id 1 --ep-iface-number 4 --set-client-id wds,14
Mon Jan 29 17:57:09 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-ip-family ipv4 --set-client-id wds,14
Mon Jan 29 17:57:09 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-client-id wds,14 --start-network --apn internet --profile 1 --auth-type none --username --password
Mon Jan 29 17:57:09 2024 daemon.notice netifd: mob1s1a1 (11256): pdh4: 960656288
Mon Jan 29 17:57:09 2024 daemon.notice netifd: mob1s1a1 (11256): 960656288
Mon Jan 29 17:57:09 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:09 2024 daemon.notice netifd: mob1s1a1 (11256): Setting up qmimux0
Mon Jan 29 17:57:09 2024 daemon.notice netifd: mob1s1a1 (11256): Setting dynamic MTU: 1500 on qmimux0
Mon Jan 29 17:57:09 2024 daemon.notice netifd: Interface 'mob1s1a1' is now up
Mon Jan 29 17:57:09 2024 daemon.notice netifd: Network device 'wwan0' link is up
Mon Jan 29 17:57:09 2024 daemon.err tailscaled[5319]: 2024/01/29 17:57:09 monitor: [unexpected] network state changed, but stringification didn't: interfaces.State{defaultRoute=eth1 ifs={br-lan:[192.168.140.1/24 fd48:91a3:f935::1/60 llu6] eth1:[192.168.99.210/24 llu6] tailscale0:[100.108.33.8/32 fd7a:115c:a1e0::72ac:2108/128 llu6]} v4=true v6=true}
Mon Jan 29 17:57:09 2024 daemon.err tailscaled[5319]: 2024/01/29 17:57:09 monitor: [unexpected] old: {"InterfaceIPs":{"br-lan":["192.168.140.1/24","fd48:91a3:f935::1/60","fe80::2297:27ff:fe1b:79c8/64"],"erspan0":null,"eth0":null,"eth1":["192.168.99.210/24","fe80::2297:27ff:fe1b:79c9/64"],"gre0":null,"gretap0":null,"ip6gre0":null,"ip6tnl0":null,"lo":["127.0.0.1/8","::1/128"],"miireg":null,"sit0":null,"tailscale0":["100.108.33.8/32","fd7a:115c:a1e0::72ac:2108/128","fe80::b6ee:3bac:3f7c:3e1a/64"],"wlan0":["fe80::2297:27ff:fe1b:79ca/64"],"wlan1":["fe80::2297:27ff:fe1b:79cb/64"],"wwan0":null},"Interface":{"br-lan":{"Index":14,"MTU":1500,"Name":"br-lan","HardwareAddr":"IJcnG3nI","Flags":51,"AltAddrs":null,"Desc":""},"erspan0":{"Index":8,"MTU":1450,"Name":"erspan0","HardwareAddr":null,"Flags":18,"AltAddrs":null,"Desc":""},"eth0":{"Index":2,"MTU":1500,"Name":"eth0","HardwareAddr":"IJcnG3nI","Flags":51,"AltAddrs":null,"Desc":""},"eth1":{"Index":3,"MTU":1500,"Name":"eth1","HardwareAddr":"IJcnG3nJ","Flags":51,"AltAddrs":null,"Desc":""
Mon Jan 29 17:57:09 2024 daemon.err tailscaled[5319]: 2024/01/29 17:57:09 monitor: [unexpected] new: {"InterfaceIPs":{"br-lan":["192.168.140.1/24","fd48:91a3:f935::1/60","fe80::2297:27ff:fe1b:79c8/64"],"erspan0":null,"eth0":null,"eth1":["192.168.99.210/24","fe80::2297:27ff:fe1b:79c9/64"],"gre0":null,"gretap0":null,"ip6gre0":null,"ip6tnl0":null,"lo":["127.0.0.1/8","::1/128"],"miireg":null,"qmimux0":null,"sit0":null,"tailscale0":["100.108.33.8/32","fd7a:115c:a1e0::72ac:2108/128","fe80::b6ee:3bac:3f7c:3e1a/64"],"wlan0":["fe80::2297:27ff:fe1b:79ca/64"],"wlan1":["fe80::2297:27ff:fe1b:79cb/64"],"wwan0":["fe80::b4a9:20ff:fe8b:5967/64"]},"Interface":{"br-lan":{"Index":14,"MTU":1500,"Name":"br-lan","HardwareAddr":"IJcnG3nI","Flags":51,"AltAddrs":null,"Desc":""},"erspan0":{"Index":8,"MTU":1450,"Name":"erspan0","HardwareAddr":null,"Flags":18,"AltAddrs":null,"Desc":""},"eth0":{"Index":2,"MTU":1500,"Name":"eth0","HardwareAddr":"IJcnG3nI","Flags":51,"AltAddrs":null,"Desc":""},"eth1":{"Index":3,"MTU":1500,"Name":"eth1","HardwareAddr":"IJc
Mon Jan 29 17:57:09 2024 daemon.err tailscaled[5319]: 2024/01/29 17:57:09 LinkChange: major, rebinding. New state: interfaces.State{defaultRoute=eth1 ifs={br-lan:[192.168.140.1/24 fd48:91a3:f935::1/60 llu6] eth1:[192.168.99.210/24 llu6] tailscale0:[100.108.33.8/32 fd7a:115c:a1e0::72ac:2108/128 llu6]} v4=true v6=true}
Mon Jan 29 17:57:09 2024 daemon.err tailscaled[5319]: 2024/01/29 17:57:09 dns: Set: {DefaultResolvers:[192.168.99.128] Routes:{tail373d4.ts.net.:[] ts.net.:[199.247.155.53 2620:111:8007::53]}+65arpa SearchDomains:[tail373d4.ts.net.] Hosts:5}
Mon Jan 29 17:57:09 2024 daemon.err tailscaled[5319]: 2024/01/29 17:57:09 dns: Resolvercfg: {Routes:{.:[192.168.99.128] ts.net.:[199.247.155.53 2620:111:8007::53]} Hosts:5 LocalDomains:[tail373d4.ts.net.]+65arpa}
Mon Jan 29 17:57:09 2024 daemon.err tailscaled[5319]: 2024/01/29 17:57:09 dns: OScfg: {Nameservers:[100.100.100.100] SearchDomains:[tail373d4.ts.net.] }
Mon Jan 29 17:57:09 2024 daemon.err tailscaled[5319]: 2024/01/29 17:57:09 wgengine: set DNS config again after major link change
Mon Jan 29 17:57:09 2024 daemon.err tailscaled[5319]: 2024/01/29 17:57:09 Rebind; defIf="eth1", ips=[192.168.99.210/24 fe80::2297:27ff:fe1b:79c9/64]
Mon Jan 29 17:57:09 2024 daemon.err tailscaled[5319]: 2024/01/29 17:57:09 magicsock: 1 active derp conns: derp-4=cr1h44m0s,wr370ms
Mon Jan 29 17:57:09 2024 daemon.err tailscaled[5319]: 2024/01/29 17:57:09 post-rebind ping of DERP region 4 okay
Mon Jan 29 17:57:09 2024 daemon.notice netifd: mob1s1a1 (11256): Setting up qmimux0 V4 DCHP
Mon Jan 29 17:57:10 2024 user.notice mwan3-hotplug[11529]: Execute ifup event on interface mob1s1a1 (wwan0)
Mon Jan 29 17:57:10 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:10 2024 daemon.err tailscaled[5319]: 2024/01/29 17:57:10 Accept: TCP{192.168.140.1:80 > 100.76.4.165:62125} 116 ok out
Mon Jan 29 17:57:11 2024 user.info mwan3track[3204]: Detect ifup event on interface mob1s1a1 ()
Mon Jan 29 17:57:11 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:11 2024 user.notice firewall: Reloading firewall due to ifup of mob1s1a1 (wwan0)
Mon Jan 29 17:57:12 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:13 2024 daemon.info dnsmasq[24761]: read /etc/hosts - 4 addresses
Mon Jan 29 17:57:13 2024 daemon.info dnsmasq[24761]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Mon Jan 29 17:57:13 2024 daemon.info dnsmasq-dhcp[24761]: read /etc/ethers - 0 addresses
Mon Jan 29 17:57:13 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:14 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:15 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:16 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:17 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:18 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:19 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:20 2024 daemon.err tailscaled[5319]: 2024/01/29 17:57:20 Accept: TCP{100.76.4.165:62107 > 192.168.140.1:80} 52 tcp non-syn
Mon Jan 29 17:57:20 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:21 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:22 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:23 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:24 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:25 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:26 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:27 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:28 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:28 2024 daemon.err mobifd: [gsm.modem0] GSM error in "mb_get_active_sim:648" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:28 2024 daemon.err mobifd: [gsm.modem0] Unable to get active SIM
Mon Jan 29 17:57:29 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:30 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:30 2024 daemon.err tailscaled[5319]: 2024/01/29 17:57:30 Accept: TCP{192.168.140.1:80 > 100.76.4.165:62107} 55 ok out
Mon Jan 29 17:57:31 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:31 2024 daemon.err mobifd: [gsm.modem0] GSM error in "mb_get_active_sim:648" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:31 2024 daemon.err mobifd: [gsm.modem0] Unable to get active SIM
Mon Jan 29 17:57:32 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:33 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:34 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:34 2024 daemon.err mobifd: [gsm.modem0] GSM error in "mb_get_active_sim:648" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:34 2024 daemon.err mobifd: [gsm.modem0] Unable to get active SIM
Mon Jan 29 17:57:35 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:36 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:37 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:37 2024 daemon.err mobifd: [gsm.modem0] GSM error in "mb_get_active_sim:648" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:37 2024 daemon.err mobifd: [gsm.modem0] Unable to get active SIM
Mon Jan 29 17:57:38 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:39 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:40 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:40 2024 daemon.err mobifd: [gsm.modem0] GSM error in "mb_get_active_sim:648" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:40 2024 daemon.err mobifd: [gsm.modem0] Unable to get active SIM
Mon Jan 29 17:57:40 2024 daemon.err tailscaled[5319]: 2024/01/29 17:57:40 Accept: TCP{192.168.140.1:80 > 100.76.4.165:62107} 55 ok out
Mon Jan 29 17:57:41 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:42 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:43 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:43 2024 daemon.err mobifd: [gsm.modem0] GSM error in "mb_get_active_sim:648" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:43 2024 daemon.err mobifd: [gsm.modem0] Unable to get active SIM
Mon Jan 29 17:57:44 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:45 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:46 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:46 2024 daemon.err mobifd: [gsm.modem0] GSM error in "mb_get_active_sim:648" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:46 2024 daemon.err mobifd: [gsm.modem0] Unable to get active SIM
Mon Jan 29 17:57:47 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:48 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:49 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:49 2024 daemon.err mobifd: [gsm.modem0] GSM error in "mb_get_active_sim:648" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:49 2024 daemon.err mobifd: [gsm.modem0] Unable to get active SIM
Mon Jan 29 17:57:50 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:51 2024 daemon.err tailscaled[5319]: 2024/01/29 17:57:51 Accept: TCP{100.76.4.165:62136 > 192.168.140.1:80} 64 tcp ok
Mon Jan 29 17:57:51 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:52 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:52 2024 daemon.err mobifd: [gsm.modem0] GSM error in "mb_get_active_sim:648" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:52 2024 daemon.err mobifd: [gsm.modem0] Unable to get active SIM
Mon Jan 29 17:57:53 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:54 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:55 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:55 2024 daemon.err mobifd: [gsm.modem0] GSM error in "mb_get_active_sim:648" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:55 2024 daemon.err mobifd: [gsm.modem0] Unable to get active SIM
Mon Jan 29 17:57:56 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:57 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:58 2024 daemon.err mobifd: [gsm.modem0] GSM error in "sim_switch:128" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:58 2024 daemon.err mobifd: [gsm.modem0] GSM error in "mb_get_active_sim:648" (Not found), gsmd_method_id: "108"
Mon Jan 29 17:57:58 2024 daemon.err mobifd: [gsm.modem0] Unable to get active SIM
