Problem solved
Just modifying through cli (ssh) the configuration of the dhcp in the mobile interface.
Like this:
Hello @Rovie @mtk_matrix ,
I’ve consulted with our developers regarding this issue, and they suggested adding the line option dhcp '0' to the config interface 'mob1s1a1' section to resolve it. Here are the steps to make this change:
- Log in to your router via CLI (more details here: Command Line Interfaces)
- Run the command
vi /etc/config/network - Locate
config interface 'mob1s1a1'and press “i” to enter edit mode - Add the line
option dhcp '0'under the mobile configuration section - Press “Esc”, then type
:wqand hit Enter to save and close the file
Thanks to Marija and all the Teltonika team for the help
