RUTX50 bug in Bands in Status > Network > Mobile
Hello
For NR5G bands in NSA aggregations, the positions of RSRP and RSRQ should be swapped
root@RUTX50:~# gsmctl -A 'AT+QCAINFO'
+QCAINFO: "PCC",1301,100,"LTE BAND 3",1,13,-68,-6,-40,17
+QCAINFO: "SCC",300,100,"LTE BAND 1",1,23,-78,-6,-62,19,0,-,-
+QCAINFO: "SCC",154090,1,"NR5G BAND 28",326
root@RUTX50:~# ubus call gsm.modem0 exec '{"command":"AT+QENG=\"servingcell\""}'
        "request": "AT+QENG=\"servingcell\"\r",
        "response": "\r\n+QENG: \"servingcell\",\"NOCONN\"\r\n+QENG: \"LTE\",\"FDD\",219,02,9F5D0D,13,1301,3,5,5,2BC9,-69,-8,-43,20,15,-300,-\r\n+QENG: \"NR5G-NSA\",219,02,326,-8,20,-69,154090,28,1,255\r\n\r\nOK\r\n"
Same under 07.08.2?
Could you please check if the issue persists with the 7.08.03 firmware version? You can download it here: RUTX50 Firmware Downloads - Teltonika Networks Wiki.
According to the manual of RG501Q module everything looks correct. But the values of RSRP and RSRQ are not in their normal range. It might a bug in module software.
+QENG: "NR5G-NSA",<MCC>,<MNC>,<PCID>,<RSRP>,<SINR>,<RSRQ>,<ARFCN>,<band>```
Respone from your module:
MCC= 219
MNC=02
PCID=326
RSRP=-8
SINR=20
RSRQ=-69
ARFCN=154090
still the same problem…
I noticed that sometimes it switches between B28 and N28 bands
Only in the N28 bands are RSRP and RSRQ swapped
Thanks :slight_smile:
+QCAINFO: "PCC",1301,100,"LTE BAND 3",1,13,-70,-7,-41,21
+QCAINFO: "SCC",300,100,"LTE BAND 1",1,23,-78,-8,-60,-10,0,-,-
        "response": "\r\n+QENG: \"servingcell\",\"NOCONN\"\r\n+QENG: \"LTE\",\"FDD\",219,02,9F5D0D,13,1301,3,5,5,2BC9,-70,-7,-44,21,11,-280,-\r\n+QENG: \"NR5G-NSA\",219,02,326,-7,21,-70,154090,28,1,255\r\n\r\nOK\r\n"
        "response": "\r\n+QENG: \"servingcell\",\"NOCONN\"\r\n+QENG: \"LTE\",\"FDD\",219,02,9F5D0D,13,1301,3,5,5,2BC9,-71,-9,-39,21,15,-,-\r\n+QENG: \"NR5G-NSA\",219,02,326,-9,21,-71,154090,28,1,255\r\n\r\nOK\r\n"
root@RUTX50:~#
Thank you for confirming that. I’ve informed our development team about the issue, and I’ll update you as soon as I receive any feedback from them.
Best Regards
To analyze why the module is returning these values, we will need to schedule a remote session. I have sent you a form to complete. Once you have filled it out, I will contact you privately to arrange the session. Please use ticket ID “7309” when completing the form.
Hello @tirkiz,
Could you please confirm if you received our email regarding the remote session? We haven’t received a response from you yet.
sorry, I sent an email :slight_smile:
Thank you! I’ve received your email.
Our developers are actively working on resolving this issue, and the fix is expected to be included in the 7.11 firmware version. We apologize for any inconvenience and appreciate your patience and understanding.
