I’ve had it a couple of times already that after resetting a Rutx50 or Rutx09 to factory defaults, it becomes unreachable. In the past, when I executed the factory defaults (either form WUI or CLI), it came back online at the 192.168.1.1 ip address. But in recent firmwares this is no longer the case. Also a poweroff/poweron after the factory reset, does not bring back the device. Only thing that works is resetting it from a hardware perspective by holding the pin/reset button. Some Rutx devices are in challenging environments, making it very difficult to reach it physically. The most recent firmware on the device was the latest (RUTX_R_00.07.05.4).
Thanks for your reply. I’m well aware of the restore options. Problem is that some device are in hard to reach locations. So being able to recover a device via the build in 192.168.1.1 ip is crucial. Is it a known issue that sometimes the Rutx devices won’t boot up correctly (with 192.168.1.1) after giving it a factory default from WUI or CLI?
