Hey guys,
im using a Rutx50 router with poynting epnt-4 via poe injector and ethernet switch atm. The built looks like following:
Poe injector —> rutx50 —> non poe switch —> pc/tv
Both, the poe injector and the non poe switch needs energy, place and cables. Is it possibile to replace them with only a poe switch?
Would look like:
Poe switch —> energy to rutx50 —> data back to poe switch (same cable) —> pc/tv
Im just wondering if it would work to bring the energy to the rutx50 and data back and split at the same time? Would be like a poe injector with 2 lan slots instead just one. (which I cant find anywhere)
But usually the 4 port poe switches have 5 slots, 1 for router and 4 for cameras, wifi access point etc. I have no idea if the router slot gives energy too or if it would work if use the router on one of the 4 poe slots? Im a bit lost with this after 2h of google‘ing.
Greetings
