Hello
Hope to get some support from Teltonika on this issue.
Description:
A reproducible issue has been identified where the 2.4GHz radio module crashes after a short uptime and following the transfer of only a few hundred megabytes of data.
Environment & Configuration:
- Router Configuration: MultiAP is enabled for the 2.4GHz band.
- Client Connection: Clients can connect via either the 5GHz or 2.4GHz band.
- Uplink Settings: Encryption settings appear irrelevant to the stability; crashes occur in various environments, including secured/insecure campsite APs and at home using OpenWRT-based routers.
Affected Scenarios:
- The issue occurs exclusively when MultiAP is enabled on the 2.4GHz band.
- No crashes are observed when MultiAP is configured for the 5GHz band.
Expected Behavior:
Stable radio connection without crashes regardless of uptime or data volume, provided MultiAP is active.
Actual Behavior:
The 2.4GHz radio module fails after a brief period of operation.
Steps to Reproduce:
- Configure the router with MultiAP mode enabled for the 2.4GHz band.
- Establish a connection with a client device.
- Initiate data transfer (a few hundred MB is sufficient).
- Monitor system status over a short duration.
Additional Information:
The issue is not new, I observed it frist time in 2025, but took me while to debug it more detail this year.
Because I cannou upload files as new users, here’s extract of the kernel exception trace taht happends:
[ 4819.049971] ath10k_ahb a000000.wifi: bss channel survey timed out
[ 4822.090009] ath10k_ahb a000000.wifi: wmi command 36892 timeout, restarting hardware
[ 4822.090102] ath10k_ahb a000000.wifi: failed to set dtim period for vdev 0: -11
[ 4822.096744] ath10k_ahb a000000.wifi: failed to recalculate rts/cts prot for vdev 0: -108
[ 4822.104072] ath10k_ahb a000000.wifi: failed to set cts protection for vdev 0: -108
[ 4822.112660] ath10k_ahb a000000.wifi: failed to set erp slot for vdev 0: -108
[ 4822.119694] ath10k_ahb a000000.wifi: failed to set preamble for vdev 0: -108
[ 4822.126797] ath10k_ahb a000000.wifi: failed to set mgmt tx rate -108
[ 4822.156799] ieee80211 phy0: Hardware restart was requested
[ 4822.160291] ath10k_ahb a000000.wifi: failed to halt axi bus: 0
[ 4822.335487] ath10k_ahb a000000.wifi: Failed to get pcie state addr: -16
[ 4822.335600] ath10k_ahb a000000.wifi: failed to setup init config: -16
[ 4822.341205] ath10k_ahb a000000.wifi: Could not init hif: -16
[ 4822.347610] ------------[ cut here ]------------
[ 4822.353580] WARNING: CPU: 3 PID: 32533 at backports-6.12.6/net/mac80211/util.c:1828 ieee80211_reconfig+0xdb4/0x1008 [mac80211]
[ 4822.357906] Hardware became unavailable during restart.
[ 4822.369147] Modules linked in: pppoe ppp_async l2tp_ppp ath10k_pci(O) ath10k_core(O) ath(O) qmi_wwan pptp pppox ppp_mppe ppp_generic option mac80211(O) ipt_REJECT cfg80211(O) cdc_ncm cdc_ether xt_time xt_tcpudp xt_tcpmss xt_statistic xt_state xt_recent xt_policy xt_nat xt_multiport xt_mark xt_mac xt_limit xt_length xt_hl xt_helper xt_hashlimit xt_esp xt_ecn xt_dscp xt_coova(O) xt_conntrack xt_connmark xt_connlimit xt_connbytes xt_comment xt_TCPMSS xt_REDIRECT xt_NFLOG xt_MASQUERADE xt_LOG xt_HL xt_FLOWOFFLOAD xt_DSCP xt_CT xt_CLASSIFY xfrm_interface wireguard usbnet usb_wwan ts_fsm ts_bm slhc sch_cake rfcomm pl2303 nft_reject_ipv6 nft_reject_ipv4 nft_reject_inet nft_reject nft_redir nft_quota nft_numgen nft_log nft_limit nft_hash nft_fwd_netdev nft_dup_netdev nft_ct nfnetlink_log nf_tables nf_reject_ipv4 nf_nat_tftp nf_nat_snmp_basic nf_nat_sip nf_nat_pptp nf_nat_irc nf_nat_h323 nf_nat_ftp nf_nat_amanda nf_log_syslog nf_flow_table nf_dup_netdev nf_conntrack_tftp nf_conntrack_snmp nf_conntrack_sip nf_conntrack_pptp
[ 4822.369765] nf_conntrack_netlink nf_conntrack_irc nf_conntrack_h323 nf_conntrack_ftp nf_conntrack_broadcast ts_kmp nf_conntrack_amanda nf_conncount libcrc32c libchacha20poly1305 iptable_raw iptable_nat iptable_mangle iptable_filter ipt_ah ipt_ECN ip6table_raw ip_tables hidp hci_uart ftdi_sio cypress_m8 curve25519_neon cp210x compat(O) ch343 ch341 cdc_wdm cdc_acm btusb btrtl btintel bnep bluetooth belkin_sa asn1_decoder ark3116 act_ipt pulse_counter(O) cypress_serial(O) usbserial sch_tbf sch_ingress sch_htb sch_hfsc em_u32 cls_u32 cls_route cls_matchall cls_fw cls_flow cls_basic act_skbedit act_mirred act_gact hid evdev input_core tlt_gpio(O) xt_set ip_set_list_set ip_set_hash_netportnet ip_set_hash_netport ip_set_hash_netnet ip_set_hash_netiface ip_set_hash_net ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set nfnetlink ip6table_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 ip6t_NPT
[ 4822.442516] ip6table_mangle ip6table_filter ip6_tables ip6t_REJECT x_tables nf_reject_ipv6 msdos ip6_gre ip_gre gre ifb l2tp_ip6 l2tp_ip l2tp_eth l2tp_netlink l2tp_core ipcomp6 xfrm6_tunnel esp6 ah6 xfrm4_tunnel ipcomp esp4 ah4 ip6_tunnel tunnel6 tunnel4 ip_tunnel vrf tun ovpn_dco_v2(O) udp_tunnel ip6_udp_tunnel xfrm_user xfrm_ipcomp af_key xfrm_algo vfat fat ntfs autofs4 nls_utf8 nls_iso8859_1 nls_cp437 ecdh_generic ecc algif_skcipher algif_rng algif_hash algif_aead af_alg echainiv cmac usb_storage leds_gpio xhci_plat_hcd xhci_pci xhci_hcd dwc3 dwc3_qcom uhci_hcd sd_mod scsi_mod scsi_common r2ec(O) gpio_button_hotplug(O) ext4 mbcache jbd2 exfat mii crc32c_generic
[ 4822.590589] CPU: 3 PID: 32533 Comm: kworker/3:0 Tainted: G O 6.6.126 #0
[ 4822.612759] Hardware name: Generic DT based system
[ 4822.620563] Workqueue: events_freezable ieee80211_restart_work [mac80211]
[ 4822.625436] unwind_backtrace from show_stack+0x10/0x14
[ 4822.632283] show_stack from dump_stack_lvl+0x40/0x4c
[ 4822.637314] dump_stack_lvl from __warn+0x98/0xc0
[ 4822.642523] __warn from warn_slowpath_fmt+0x10c/0x174
[ 4822.647211] warn_slowpath_fmt from ieee80211_reconfig+0xdb4/0x1008 [mac80211]
[ 4822.652327] ieee80211_reconfig [mac80211] from ieee80211_restart_work+0xd4/0x148 [mac80211]
[ 4822.659457] ieee80211_restart_work [mac80211] from process_scheduled_works+0x1e0/0x394
[ 4822.668050] process_scheduled_works from worker_thread+0x190/0x3dc
[ 4822.675771] worker_thread from kthread+0xe8/0x104
[ 4822.682019] kthread from ret_from_fork+0x14/0x28
[ 4822.686879] Exception stack(0xc71c1fb0 to 0xc71c1ff8)
[ 4822.691657] 1fa0: 00000000 00000000 00000000 00000000
[ 4822.696699] 1fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4822.704858] 1fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 4822.713062] —[ end trace 0000000000000000 ]—
[ 4822.719477] wlan0-3: deauthenticating from by local choice (Reason: 3=DEAUTH_LEAVING)
[ 4822.724743] wlan0-3: HW problem - can not stop rx aggregation for tid 0
[ 4822.733479] wlan0-3: HW problem - can not stop rx aggregation for tid 4
