RUTX50 7.17.5 email to SMS doesn't work for more than one email
Hi *,
if i send more than one email to the gateway it will loop trying to send the first email and will not remove that email from mailqueue (/tmp/spool/emailrelay).
If i send only one email it works.
Is there any solution for that already?
best regards,
Michael
Thank you for your inquiry. We will test this functionality and get back to you.
We appreciate your patience.
@Marija
Dear Marija,
it seems to be a type mismatch in line 130.
Size is a string, not a number.
I have seen:
/usr/bin/lua: /usr/bin/email_to_sms:130: attempt to compare number with string
Michael
Hello again,
To troubleshoot the issue further, we’ll need to review your device’s troubleshoot file. I’ve sent a form to the email address you used to register on the forum. Once you’ve filled it out, we’ll contact you privately.
Please use “16107” as the ticket ID when completing the form.
