I have attached my Starlink (through original Ethernet Adapter) to the WAN port oft he RUTX14 (with latest fw: RUTX_R_00.07.07.2) and I found out, that the internet connection reaches only (maximum) 30 Mbit/s download speed. When I connect the computer directly to the Starlink system (via Ethernet Adapter) the download speed reaches up to 180 Mbit/s.
I did already try some options, suggested in other threads in this board, as e.g. „turn on Software flow offloading option“ as well as „Override MTU field try the following values: 1420, 1460, 1472“ … unfortunately without any success.
Additionally I found out, when I switch off Masquerading the zones in the firewall section (pls. see screenshot), the download speed is going up above 100 Mbit/s. So I think this issue is related somehow to the firewall. Unfortunately, when I switch off Masquerading the zones in the firewall section, the devices connected to the LAN ports went offline, so this won’t be an option.
As I also saw in this board, I am not alone with this Starlink – WAN-Port issue, so pls investigate.
Thanks in advance & best regards
