RUTX14 “Services>Input/Output>Status” page empty
“Services>Input/Output>Status” page is empty on my RUTX14 (RUTX_R_00.07.18.2). After reboot same issue. Also event juggler shows “no option available” for “I/O pin name” options on “event data configuration” page. What can I do to solve this? Note, return to factory settings is not an option at the moment as I have no physical access to the modem.
To investigate the issue further, we will need some sensitive information like troubleshoot file. I have sent a form to the email address you used to register on the forum. Once you have filled out the form, you will receive a private email from us.
Please use “16118” as the ticket ID when completing the form.
