Hi.
RUTX14:
RUT241:
Configured as per the link: Wireless Mesh configuration example - Teltonika Networks Wiki
There is a connection between the devices, but there is no internet on the node.
I disabled DHCP on the node, it doesn’t help.
Hi.
RUTX14:
I tested the configuration according to the WIKI and found some inaccuracies in the settings:
You need to disable the DHCP server on the nodes.
If this does not solve the problem, you need to manually configure a static route to the router on each node.
