RUTX14 LTE modem failure
My router constantly loses LTE connection. Firmware RUTX_R_00.07.10.2. Quectel EG12-EA modem firmware version: EG12EAPAR01A09M4G_01.001.01.001. Update available, but not allowed due to missing LTE connection. WAN port has internet.
Signal LTE B7(when modem switches on):
RSSI -39
RSRP -72
RSRQ -7
SINR +23
root@RUTX14:~# lsusb
Bus 003 Device 001: ID 1d6b:0002
Bus 001 Device 001: ID 1d6b:0002
Bus 003 Device 003: ID 0a12:0001
Bus 001 Device 002: ID 2c7c:0512
Bus 004 Device 001: ID 1d6b:0003
Bus 002 Device 001: ID 1d6b:0003
Bus 003 Device 002: ID 05e3:0610
root@RUTX14:~# modem_updater -g
[INFO] Detected MODEM_N: 0
Modem List:
[0] Quectel EG12-EA
lte operator | USB_ID: 1-1 | Firmware: EG12EAPAR01A09M4G_01.001.01.001 | builtin:true
Available versions (highest version number first):
EG12EAPAR01A15M4G_01.201.01.201
EG12EAPAR01A14M4G_01.200.01.200
EG12EAPAR01A11M4G_01.001.01.001
EG12EAPAR01A10M4G_01.001.01.001
EG12EAPAR01A06M4G
root@RUTX14:~# ll /dev/ttyUSB*
crw-rw---- 1 root dialout 188, 0 Oct 30 09:59 /dev/ttyUSB0
crw-rw---- 1 root dialout 188, 1 Oct 30 09:59 /dev/ttyUSB1
crw-rw---- 1 root dialout 188, 2 Nov 24 10:49 /dev/ttyUSB2
crw-rw---- 1 root dialout 188, 3 Oct 30 09:59 /dev/ttyUSB3
Is it possible to get help here? I received no feedback from the Teltonika Networks Contact Us Form.
If your router has a wired WAN connection, it should be able to upgrade the modem’s firmware using the modem_updater tool.
Could you confirm if the SSHFS package is installed on your router? If not, please install it via System → Package Manager. Once installed, you can proceed to update the modem firmware through an SSH connection. Use the following command to update the firmware to your desired version: modem_updater -v <VERSION>
Replace <VERSION> with the desired firmware version, such as EG12EAPAR01A15M4G_01.201.01.201.
If you encounter any issues or need further assistance, feel free to reach out.
Hi Martynas,
I tried this last night, i got this:
modem_updater -v EG12EAPAR01A15M4G_01.201.01.201 -D
[INFO] 0 is responding to AT commands.
[INFO] MODEM_USB_ID: 1-1
[INFO] DEVICE is compatible.
[000.000]: Version: QFirehose_Linux_Android_V1.4.18
[000.000]: Builded: Oct 30 2024 08:59:19
[000.000]: qusb_read_speed_atime speed: 480, st_atime: 20241123_16:58:09
[000.001]: P: /dev/bus/usb/001/006 idVendor=2c7c idProduct=0512
[000.001]: C: /dev/bus/usb/001/006 bNumInterfaces: 5
[000.001]: I: If#= 0 Alt= 0 #EPs= 2 Cls=ff Sub=ff Prot=ff
[000.001]: E: Ad=81 Atr=02 MxPS= 512 Ivl=0ms
[000.001]: E: Ad=01 Atr=02 MxPS= 512 Ivl=0ms
[000.001]: I: If#= 1 Alt= 0 #EPs= 3 Cls=ff Sub=00 Prot=00
[000.001]: E: Ad=83 Atr=03 MxPS= 10 Ivl=9ms
[000.001]: E: Ad=82 Atr=02 MxPS= 512 Ivl=0ms
[000.001]: E: Ad=02 Atr=02 MxPS= 512 Ivl=0ms
[000.002]: I: If#= 2 Alt= 0 #EPs= 3 Cls=ff Sub=00 Prot=00
[000.002]: E: Ad=85 Atr=03 MxPS= 10 Ivl=9ms
[000.002]: E: Ad=84 Atr=02 MxPS= 512 Ivl=0ms
[000.003]: E: Ad=03 Atr=02 MxPS= 512 Ivl=0ms
[000.003]: I: If#= 3 Alt= 0 #EPs= 3 Cls=ff Sub=00 Prot=00
[000.003]: E: Ad=87 Atr=03 MxPS= 10 Ivl=9ms
[000.003]: E: Ad=86 Atr=02 MxPS= 512 Ivl=0ms
[000.003]: E: Ad=04 Atr=02 MxPS= 512 Ivl=0ms
[000.004]: I: If#= 4 Alt= 0 #EPs= 3 Cls=ff Sub=ff Prot=ff
[000.004]: tmp=/sys/bus/usb/devices/usb1/…/driver, driver=…/…/…/…/…/…/bus/platform/drivers/xhci-hcd
[000.005]: qusb_noblock_open port_name = /dev/ttyUSB0
[001.007]: poll_wait events=POLLIN msec=1000 timeout
[001.007]: switch to ‘Emergency download mode’
[001.009]: successful, wait module reboot
[INFO] internet connection is working
[INFO] Downloading key
[INFO] Checking old mount
[INFO] Old mount: Empty
[INFO] Timeout waiting for prompt
[ERROR] Timeout while mounting with sshfs. Your ISP might be blocking ssh connections.
[INFO] Starting services:
[INFO] Starting gsmd
[INFO] Starting modem_trackd
[INFO] Starting ledman
[INFO] Starting ping_reboot
[INFO] Waiting for modem: 0
[handle_requests:429] error: Failed to handle AT exec. ERR: Not found
I do not have the opportunity change ISP. Should I try again?
Thank you
Based on the logs, the issue appears to be related to the sshfs mounting process. The timeout error suggests that your ISP may indeed be interfering with the sshfs communication required for the update process.
In this case, I’ve sent you a form to fill out. For the ticket ID, please use “10591”. Once submitted, we’ll contact you privately and provide an alternative method for updating the modem firmware.
Hello
After update my RUTX14 modem firmware (from router admin page), the modem fail to connect.
I need help to solve this topic
Thank you
Could you please confirm the firmware version to which you updated the RUTX14 modem? Additionally, did the firmware upgrade complete successfully without any errors?
To help resolve the issue, could you try installing the SSHFS package through the WebUI by navigating to System → Package Manager? Before proceeding, please ensure that the router has a wired WAN connection.
Once the SSHFS package is installed, connect to the router’s CLI and execute the following commands:
  1. opkg update && opkg install modem_updater;
  2. modem_updater -g – check the current modem firmware version;
  3. modem_updater -v <version> – upgrade the modem firmware to the latest version available on the server.
Please let us know if you need any further assistance.
Hello Martynas
I confirm the firmware version of my RUTX14: RUTX_R_00.07.11
SSHFS package - already installed
opkg update && opkg install modem_updater - done
It was necesary a reboot of the router and everything working fine (see below).
Thank you very much Martynas!
All the best
root@Teltonika-RUTX14:~# modem_updater -g
Modem List:
[0] Quectel EG12-EA
Vodafone RO | USB_ID: 1-1 | Firmware: EG12EAPAR01A09M4G_01.001.01.001 | builtin:true
EG12EAPAR01A06M4G
root@Teltonika-RUTX14:~# modem_updater -v EG12EAPAR01A15M4G_01.201.01.201
[000.001]: Builded: Nov 22 2024 12:24:43
[000.001]: qusb_read_speed_atime speed: 480, st_atime: 20241127_14:30:04
[000.002]: P: /dev/bus/usb/001/002 idVendor=2c7c idProduct=0512
[000.002]: C: /dev/bus/usb/001/002 bNumInterfaces: 5
[000.002]: I: If#= 0 Alt= 0 #EPs= 2 Cls=ff Sub=ff Prot=ff
[000.002]: E: Ad=81 Atr=02 MxPS= 512 Ivl=0ms
[000.002]: E: Ad=01 Atr=02 MxPS= 512 Ivl=0ms
[000.002]: I: If#= 1 Alt= 0 #EPs= 3 Cls=ff Sub=00 Prot=00
[000.002]: E: Ad=83 Atr=03 MxPS= 10 Ivl=9ms
[000.002]: E: Ad=82 Atr=02 MxPS= 512 Ivl=0ms
[000.002]: E: Ad=02 Atr=02 MxPS= 512 Ivl=0ms
[000.002]: E: Ad=03 Atr=02 MxPS= 512 Ivl=0ms
[000.002]: I: If#= 3 Alt= 0 #EPs= 3 Cls=ff Sub=00 Prot=00
[000.002]: E: Ad=87 Atr=03 MxPS= 10 Ivl=9ms
[000.002]: E: Ad=86 Atr=02 MxPS= 512 Ivl=0ms
[000.002]: E: Ad=04 Atr=02 MxPS= 512 Ivl=0ms
[000.002]: I: If#= 4 Alt= 0 #EPs= 3 Cls=ff Sub=ff Prot=ff
[000.003]: tmp=/sys/bus/usb/devices/usb1/…/driver, driver=…/…/…/…/…/…/bus/platform/drivers/xhci-hcd
[000.003]: qusb_noblock_open port_name = /dev/ttyUSB0
[001.005]: poll_wait events=POLLIN msec=1000 timeout
[001.005]: switch to ‘Emergency download mode’
[001.007]: successful, wait module reboot
[INFO] Stopping services:
[INFO] Stopping gsmd
[INFO] Stopping modem_trackd
Command failed: Not found
[INFO] Stopping ledman
[INFO] Stopping ping_reboot
DO NOT TURN OFF YOUR DEVICE DURING THE UPDATE PROCESS!
Starting flasher…
[226.216]: Upgrade module successfully.
[INFO] Script finished
Modem is responding to AT commands. Modem is ready
Modem List:
[0] Quectel EG12-EA | USB_ID: 1-1 | Firmware: EG12EAPAR01A15M4G_01.201.01.201 | builtin:true
EG12EAPAR01A06M4G
