Hi, I have bought an IPKO sim card in Kosovo. It says that I need the following APN settings:
APN: IPKO
Username: (none)
Password: (none)
Proxy: 213.229.249.40
Proxy port: 8080
Unfortunately I can not find the settings for proxy and port in the router. Dan you help me with setting this up properly?
Our routers do not support this functionality. These settings are typically used for extensive monitoring and filtering, primarily targeting mobile phones. It’s a common setup for mobile connections on smartphones.
To work around this, you can connect your mobile phone and use its internet sharing (mobile hotspot) feature.
Hi, I am surprised that a router of this quality does not support this functionality. The whole point of using a rutx router for me is to be able to use the attached external antenna, which allows me to have better reception.
