RUTX14 can't find Mobotix camera
Local LAN with static IP:
  • Gateway 192.168.0.1
  • Cam1 192.168.0.100:80
  • Cam2 192.168.0.101:80
RUTX14 can’t find Cam1 after powering all on by one main switch or simultaneously in any way.
Every time Cam1 is offline, port LED is off. Cam2 is online, port LED is on.
RUTX14’s topology tab and network ports show the same state. Cam1 goes online after reconnecting Cam1 to LAN port of RUTX14.
Absence of Cam2 192.168.0.101:80 makes no difference. Every time Cam1 (type M24 or D15) is offline after powering system on.
Cam1 goes online by itself after RUTX14 software reboot or camera’s jack replugging to LAN port. Another way is to use additional switch for connecting cameras to RUTX14.
It doesn’t matter what firmware is used RUTX_R_00.07.08.3, RUTX_R_00.07.11.3 or RUTX_R_00.07.12. Mobotix cameras M24 or D15 were used for 192.168.0.101:80, different PoE’s also.
Two RUTX14 were tested. Old RUT950 works perfect with same settings. LAN configuration must remain unchanged.
