RUTX12 Wireless SSID speed limiting
I cannot find how to limit manage the wireless SSID speed limits?
It seems that I have to limit the LAN as well???
I want too prioritize LAN over Wireless. Or reduce Wireless to max 10Mbps (like I can do with LAN ports).
I am able to limit different ports to different speeds: LAN1 to LAN3 are limited to 10Mbps (FE). LAN4 is unrestricted (GbE). This allows me to prioritize my PC on LAN4 over other PCs on the network. It works well.
The RUTX12 Traffic Shaping / QoS section (RUTX12 Traffic Shaping - Teltonika Networks Wiki) does not explain how to isolate Wifi and manage Wifi speeds.
A work around is to connect another router to one of the restricted LAN ports and make that the WIFI / Wireless conenction point.
Hi…
Try at WiFi settings…
2.4GHz select 802.11g (54Mbps)
5 GHz select 802.11a (54Mbps)
I do not recommend the use of 802.11b for 2.4GHz.
Hi Marcelo, could not find any settings there to adjust? rgds Mike
Hi…
Look this URL… Will help you.
https://wiki.teltonika-networks.com/view/RUTX12_Wireless
