I have a RUTX12 which keeps reporting an inability to read one of its SIMs.
The problem first occurred with the secondary modem:
| 2224;2025-10-15 08:44:10;SIM status;events;info;SIM state changed to not inserted (secondary modem) |
| 2225;2025-10-15 08:44:20;SIM status;events;info;SIM state changed to not inserted (secondary modem) |
| 2226;2025-10-15 08:44:31;Mobile Data;network;info;Mobile data disconnected (secondary modem) |
| 2227;2025-10-15 08:45:47;Network Type;network;info;Joined LTE network (secondary modem) |
| 2228;2025-10-15 08:45:47;Network Operator;network;info;Connected to 23410 operator (secondary modem) |
| 2229;2025-10-15 08:46:08;Mobile Data;network;info;"Mobile data connected (IPv4 |
| 2230;2025-10-15 08:47:55;SIM status;events;info;SIM state changed to not inserted (secondary modem) |
| 2231;2025-10-15 08:48:02;Mobile Data;network;info;Mobile data disconnected (secondary modem) |
| 2232;2025-10-15 08:48:07;SIM status;events;info;SIM state changed to not inserted (secondary modem) |
| 2233;2025-10-15 08:50:22;Network Type;network;info;Joined LTE network (secondary modem) |
| 2234;2025-10-15 08:50:22;Network Operator;network;info;Connected to 23410 operator (secondary modem) |
| 2235;2025-10-15 08:50:29;Mobile Data;network;info;"Mobile data connected (IPv4 |
| 2236;2025-10-15 08:53:30;SIM status;events;info;SIM state changed to not inserted (secondary modem) |
| 2237;2025-10-15 08:53:45;SIM status;events;info;SIM state changed to not inserted (secondary modem) |
| 2238;2025-10-15 08:53:54;Mobile Data;network;info;Mobile data disconnected (secondary modem) |
| 2239;2025-10-15 08:55:28;Network Type;network;info;Joined LTE network (secondary modem) |
I thought maybe a faulty SIM and so I replaced this with a new SIM from a different network operator.
This indeed resolved the issue with the secondary modem - no more reports of not inserted. But then the same problem immeditely started to appear with the primary modem where I had made no change to the SIM:
| 2863;2025-10-16 16:29:23;Failover;network;info;Switched to main WAN (mob1s1a1) | ||
| 2864;2025-10-16 16:29:27;Mobile Data;network;info;"Mobile data connected (IPv4 | primary modem)" | |
| 2865;2025-10-16 16:33:00;SIM status;events;info;SIM state changed to not inserted (primary modem) | ||
| 2866;2025-10-16 16:33:03;Failover;network;info;"WAN (mob1s1a1) is down | switched to backup WAN (mob2s1a1)" | |
| 2867;2025-10-16 16:33:05;Mobile Data;network;info;Mobile data disconnected (primary modem) | ||
| 2868;2025-10-16 16:33:07;SIM status;events;info;SIM state changed to not inserted (primary modem) | ||
| 2869;2025-10-16 16:36:05;Failover;network;info;Switched to main WAN (mob1s1a1) | ||
| 2870;2025-10-16 16:36:09;Network Type;network;info;Joined LTE network (primary modem) | ||
| 2871;2025-10-16 16:36:09;Network Operator;network;info;Connected to 23415 operator (primary modem) | ||
| 2872;2025-10-16 16:36:12;Failover;network;info;Switched to main WAN (mob1s1a1) | ||
| 2873;2025-10-16 16:36:16;Mobile Data;network;info;"Mobile data connected (IPv4 | primary modem)" | |
| 2874;2025-10-16 16:42:09;SIM status;events;info;SIM state changed to not inserted (primary modem) | ||
| 2875;2025-10-16 16:42:11;Failover;network;info;"WAN (mob1s1a1) is down | switched to backup WAN (mob2s1a1)" | |
| 2876;2025-10-16 16:42:13;Mobile Data;network;info;Mobile data disconnected (primary modem) | ||
| 2877;2025-10-16 16:42:15;SIM status;events;info;SIM state changed to not inserted (primary modem) | ||
| 2878;2025-10-16 16:43:31;Failover;network;info;Switched to main WAN (mob1s1a1) | ||
| 2879;2025-10-16 16:43:36;Network Type;network;info;Joined LTE network (primary modem) | ||
| 2880;2025-10-16 16:43:36;Network Operator;network;info;Connected to 23415 operator (primary modem) | ||
| 2881;2025-10-16 16:43:38;Failover;network;info;Switched to main WAN (mob1s1a1) | ||
| 2882;2025-10-16 16:43:42;Mobile Data;network;info;"Mobile data connected (IPv4 | primary modem)" |
| So why would I have persistent SIM issues with secondary modem and none with primary, then once I change SIM in secondary I have persistent SIM issues with primary modem and none with secondary? |
