Hi
How to config rutx12 use 2 mobile sim bridge mode to fortigate?
Hello there,
Looking at the provided topology, I don’t believe that bridging both mobile interfaces into a single WAN port of your FortiGate device will be possible due to the fact that it’s not realistic to have 2 separate IP addresses on a single interface.
Say, you head to our RUTX12’s WebUI, then the Network → WAN section and hit “Edit” on one of the two mobile interfaces, and you set the protocol to “Bridge” or “Passthrough”, the interface will pass its IP to the client, of course. If you were to try and do that on both of your interfaces, you’d simply be met with the following error:
Therefore, to answer your question, this configuration is not possible to achieve.
Thank you for information
