Hello @Krobar,
Many mobile network operators use various power-saving measures to reduce energy consumption. Depending on the operator and network configuration, some frequency bands may be temporarily powered down or put into a lower-power state during periods of low network activity, such as overnight.
Basic services such as voice calls and SMS generally remain available, as operators typically keep their primary, wide-coverage low-frequency bands active. However, these practices can vary significantly depending on the mobile operator, country, and local network conditions.
Some operators may temporarily disable higher-capacity frequency layers during periods of low traffic, while others may keep all available bands active to maintain maximum network readiness. In some cases, users may notice changes in aggregate network performance or signal behavior during these periods.
Regarding why Carrier Aggregation (CA) is reported as inactive in the morning, we are currently investigating this behavior to determine the possible cause.
As a temporary workaround, you could try band locking. In the device WebUI, navigate to Network → Mobile → General and manually select the primary and secondary LTE bands supported by your local cell tower instead of leaving the band selection set to Auto.
Alternatively, you could try scheduling an automatic reboot of the device each morning. This can be configured in the WebUI under System → Maintenance → Auto Reboot → Reboot Scheduler, where you can specify a suitable time for the device to restart.
We hope this helps as a temporary workaround. Once we have more information regarding the Carrier Aggregation remaining inactive, we will get back to you as soon as possible.
We appreciate your patience and understanding.
P.
