RUTX11 WireGuard VPN Server: No Internet Access
I have set up a WireGuard VPN on my router, and the client successfully establishes a handshake. However, there is no internet access when connected to the VPN.
  • Device: Teltonika RUTX11
  • Firmware Version: RUTX_R_00.07.12
  • Not behind a CG-NAT
WireGuard Server Configuration:
Peer:
Port Forward Configuration:
none
Zoning Configuration:
WireGuard Client Configuration:
I would greatly appreciate any guidance or troubleshooting steps you could provide to help resolve this issue. Thank you for your assistance!
Hi…
Have you check your steps here?
https://wiki.teltonika-networks.com/view/RUTX11_VPN#WireGuard
Both the server and client interfaces have the same address: 10.5.0.1/24
What is the value of Allowed IPs on the server ?
Yes, I followed this guide. Even the ports are the same
What do you suggest then? If I set 10.5.0.2/24 or 10.5.0.2/32 in the WireGuard Client GUI, I still don’t have internet access.
0.0.0.0/0, ::/0
Thanks for the suggestion. I’ve set it for 10.5.0.2/24, but I still don’t have internet access.
Have a peer at this example …
On the server set Allowed IPs to 10.5.0.2/32.
Hello @wgUser,
Could you please confirm if the issue has been resolved, or do you still need any assistance with this?
