I recently updated to 07.12 firmware of my rutx11 and solved redirect problem for https connection (creating certificate and put it in windows) Everything run good but…but after of this I cannot use vpn now when I try to use my personal firewall…Any suggestion, please ?
Thank you
Anyone can help me ?
Hi…
Please… what kind of vpn are you using? ovpn? lt2p? ipsec?
OVPN? (maybe)
this is a text file… do you have the first file, when everything was working?
download the new file, after creating new certificate… you can just look at the beggining and at the end of certification text in both files… they are exactly the same number/letters?
HI Marcelo,
Sorry but I don’t understand. I’m not so good with certificates…
Can you explain me better ?
Thank You
To get any help … you will have to tell the community what sort of VPN you are using e.g. OpenVPN, Wireguard, GRE, L2TP, ZeroTier et cetera, and the relevent settings you are using.
You should also explain what you mean by ‘my personal firewall’. A diagram or drawing of your topology may help.
I use a firewall of third parties (not windows only) and I can set openvpn, or wireguard or IKEv2 but and I don’t know any other setting about that.
I know before update to 07.12 firmware and to import the new certificate for redirect http to https my vpn run normally. Now I cannot use it but I need to use it.
So I pray Teltonika to solve my problem as soon as possibile.
Thank you
Anyone can help me ??
I cannot use every pc in my lan with any vpn of the firewall !!
I have noted that vpn (wireguard or openvpn or another one) is on line but I cannot navigate in internet, in special way banking and finance.
Please please !! I need help !!
Can you ping google dns server? 8.8.8.8
yes.
But if try to connect to this site, for example https://community.teltonika.it, I cannot with vpn on. I have to close vpn by my firewall. Because I don’t how use vpn by router…sorry ![]()
okay…
You need to check about DNS… just to be sure what the VPN ON are doing in the connection… Can you go to network settings in your computer and fix the dns settings? using 8.8.8.8 as dns server in your computer?
I use 1.1.1.1 in my pc and in the router too. But I didn’t have any iussue before to put the new certificate in windows. I have also 4 pc on my lan and everyone has the same problem so I’m sure it’s a conflict with router and vpn of the firewall…I think…And now I’m thinking that I didn’t put the new certificate in the other pc…Do I have to do it ?
No…
First need to solve the issue with 7.12 and rutx11.
You need to receive a contact (@anon65719490 or ??) from Teltonika team.
I tried to change dns in my pc and rut11 ma nothing changed…![]()
Thank you very much Marcelo
Hi, I’m waiting for Martynas can help me to solve this iussue
I solved the iussue !!! ![]()
I don’t not why but In firewall setting / traffic rules, there was an incorrect rule about wireguard and the other vpn.
Now everything run normally ![]()
