I use a SSD Harddrive connecting via USB since more then 10 month. Since four weeks I have problems to add file to the network share. Result: I do not have access rights. I made an update to firmware 7.04.4 but i does not help. And I do not see the items which are displayed in the manual.
It would be best if you tried to reset the router to factory setting and try to set up everything up once again to see if it work properly
