RUTX11 & TAP200 Same SSID
I have TAP200 connected to RUTX11 and want to expand Wi-Fi coverage due to these two devices, as if they work as a mesh.
SSID must be the same.
I hope that can help.
Info in that post is 1yr old and it’s outdated as TAP200 already supports Wireless mesh (802.11s).
Although user connected TAP200 using wire (I assume) so mesh is not even needed (It is used to extend network without using wire between AP devices). You can just configure both devices to use same SSID and password and most Wi-Fi clients will be able to switch between them.
Also you can play with “802.11v BSS Transition Management” and “802.11r Fast Transition” but they are not strictly necessary and without over complicating setup u can leave them disabled.
