RUTX11 Stops Assigning IP Addresses When Connected to Grandstream Switch (Starlink in Bypass Mode)
I am experiencing an issue with my network setup involving a Teltonika RUTX12 router and a Grandstream managed switch.
Network Topology:
Starlink (Bypass Mode) → WAN port of Teltonika RUTX12 → LAN port of RUTX12 → Grandstream Switch → Client Devices
The Starlink router is configured in Bypass Mode, so it is not performing any routing or DHCP functions. The Teltonika RUTX12 is acting as the main router and DHCP server for the LAN network.
Problem Description:
When the LAN port of the RUTX12 is connected to the Grandstream switch:
  • Client devices fail to obtain IP addresses.
  • Internet connectivity stops.
  • The network becomes unstable.
However, when I disconnect the LAN cable between the RUTX12 and the switch:
  • The RUTX12 immediately resumes assigning IP addresses correctly.
  • Internet connectivity works normally for directly connected devices.
This behavior is consistent and reproducible.
Important Details:
  • There is NO network loop.
  • There is no secondary connection between the switch and Starlink.
  • The switch is only connected to the RUTX12 LAN port.
  • Starlink is confirmed to be in Bypass Mode.
  • The RUTX12 WAN interface is configured as a DHCP client.
  • The RUTX12 LAN interface is configured with DHCP server enabled.
  • The WAN port is not intentionally bridged with LAN (as far as I can see).
  • Only one DHCP server should be active (on the RUTX12).
When the issue occurs, the router does not completely power off, but client devices cannot obtain IP addresses from the LAN.
Troubleshooting Already Attempted:
  • Confirmed Starlink is in Bypass Mode.
  • Checked for physical loops — none exist.
  • Verified correct cabling (Starlink to WAN, Switch to LAN).
  • Rebooted all devices.
  • Tested with different Ethernet cables.
  • Confirmed DHCP is enabled on the RUTX12 LAN.
  • Ensured no secondary router is connected.
Despite this, the issue persists whenever the LAN is connected to the switch.
For troubleshooting purposes, we will require more sensitive information from your end, such as the troubleshoot file, which may contain passwords, public IP addresses, serial numbers, and such. To avoid leaking this information, we have sent you a form to fill out, which you will receive in your e-mail inbox that you have registered your account with in the forums. In the Ticket ID field of the form, please enter the ID of this thread, which is 18089.
the form does not have a provision for me to attach files
I have sent you an email, you can reply with the necessary information to it.
Morning
There hasn’t been any feedback from you since the time we sent the files
Could you please clarify whether you still require assistance or if the issue has already been resolved?
