I know the SDK isn’t officially supported by Teltonika. But tossing this out to see if anyone else has the same issue and has found a fix.
I’m using the SDK to build in a few modules and change a couple of default settings. Specifically the default admin password and default IP.
I’m editing the password in both places in ‘/RUTX_R_GPL_00.07.06/package/base-files/files/lib/preinit/84_set_password’ as the docs mention. The package compiles without error. However, when loading the image onto a RUTX11, the device still requires the randomly generated password from the label for admin login. I’ve also set the setting to disable the initial password change. But it’s not making any difference when compiling.
Same thing with the default IP. I’m setting the default IP using menuconfig as the docs state, it saves without error, but isn’t taking effect when compiling.
It’s acting as if the config files the SDK says to edit are being ignored when compiling.
I’ve tried this. I’ve put the network config file in package/base-files/files/etc/config/. Recompiled, it still compiles with the standard network config file that does not contain my settings. I’ve also tried putting this at the root directly. Still the same default IP settings. Somewhere I’m missing a location where the correct IP information is being set by the firmware.
All signs point to that being the solution. But it does not want to compile those network settings. Still comes out with the default. Using SDK for 7.06.6 as well. Still digging in on this. Has to be a configuration somewhere in this code that is setting this stuff.
I have a default IP changed as well as APN’s set on the mobile interfaces. I set this with a config file, but want to set it as part of the firmware. Specifically the default IP. When compiling and installing on a RUTX11, the first thing I check is the network config file and it is always default. Completely ignoring my configs.
~/RUTX_FW/rutos-ipq40xx-rutx-gpl/files/etc/config$ ls ~/RUTX_FW/rutos-ipq40xx-rutx-gpl/files/etc/config/network
/home/user/RUTX_FW/rutos-ipq40xx-rutx-gpl/files/etc/config/network
