RUTX11, RUTX10 and RUT955 are possible to connect in the loop?
We are exploring a solution to enhance network redundancy and accessibility by incorporating RUTX10, RUTX11, and RUT955 routers in a loop configuration.The proposed setup involves interconnecting the routers using Ethernet cables, establishing a resilient network architecture. This configuration not only improves system reliability but also facilitates remote access to an inoperative router through another functional one.
What we intend to use are Ethernet cables to create a physical loop connecting RUTX10, RUTX11, and RUT955 routers and utilize the built-in remote access features of the routers to establish a secure connection to any router within the loop.
Dear Serhii,
Welcome to Teltonika Networks Community !
If you are going for WAN redundancy, could you try VRRP instead.
https://wiki.teltonika-networks.com/view/VRRP_example
https://wiki.teltonika-networks.com/view/RUT955_VRRP_configuration
Clive Pinto
