my RUTX11 runs out of memory for about 2-3 times a month. Sometimes a shell reboot works but mostly not, then I have to pull the power cord. I have a screenshot from “top” but there is nothing really helpful to see. If this happens again, what should I do to find out what causes the trouble?
I have internet connection via T-Mobile 4G and a larger number of Wifi Clients, because I am using Shelly hardware for smarthome
I’m unsure which memory you’re running out of – RAM or flash. Considering you mentioned having numerous Wi-Fi-connected smart home devices, could you provide details about their configuration in your RUTX11? Specifically, do they store statistics locally or utilize other services for management?
Regardless, in future instances of the issue, please ensure to obtain a troubleshoot file. This will enable us to investigate and address the problem effectively.
Thank you, I just installed htop and figured it out, this will help the next time.
If the problem appears, the GUI is not reachable anymore.
Is there a shell command available instead?
